slow broad band
- slow broad band
slow broad band
17-08-2010 4:03 PM
hi. my broadband is running slow during stablising perod due to power cuts over weekend, was running at about 3.00 now at 1.37
has any one got any advice plse
dave
dave
Message 1 of 8
(1,298 Views)
7 REPLIES 7
Re: slow broad band
17-08-2010 4:16 PM
Leave the router powered on for at least 72 hours.
The following morning switch the router off for at least half an hour.
Switch the router back on between 10:00am and 12:00 midday.
Leave the router switched on.
Hopefully it will be back to normal.
Message 2 of 8
(574 Views)
Re: slow broad band
17-08-2010 4:18 PM
i try that mate thanks
Message 3 of 8
(574 Views)
Re: slow broad band
17-08-2010 5:11 PM
If you don't have any success then you can report it to the Faults Team here. If you'd like any clarification of the fault diagnostics or your router stats then just post them and we'll have a look
Edit: I can see that the Faults Team have already investigated this before and the underlying problem should be resolved, we might just be delayed a little due to the power cuts. As purleigh advised, the best course of action is to leave the router powered up for 72 hours and just let us know if your speeds don't increase.
Message 4 of 8
(574 Views)
Re: slow broad band
17-08-2010 8:07 PM
ok will do thanks ben
Message 5 of 8
(574 Views)
Re: slow broad band
18-08-2010 4:06 PM
these are my speed test results
FAQ
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
2187 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 2187 Kbps
Additional Information:
Your DSL Connection Rate :2944 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
FAQ
Download Speed
2187 Kbps
0 Kbps 7150 Kbps
Message 6 of 8
(574 Views)
Re: slow broad band
18-08-2010 4:41 PM
That's looking better
Your estimate was 0.5Mbps and your profile's never been stable, usually around the 1Mbps mark so hopefully we've got everything sorted now!
Message 7 of 8
(574 Views)
Re: slow broad band
18-08-2010 4:43 PM
hope so thanks ben
Message 8 of 8
(574 Views)
