sloooowwww
fastconnection
sloooowwww
Hi Plusnet folks
Usually very happy with service but dload speed slooww lately  3 to 4 mps. Can you check/reset connection please?
Fixes: 160
Re: sloooowwww
I've just been through a couple of line tests and can't see any issues. Your line is connecting at 13904 to the exchange, this is giving you a profile of 12267.
There does seem to be an inconsistency between the profile across a couple of systems, so I'm going to try what's known as an SNR reset to kick these back together.
I've also just noticed that your upload speed is capped at 448, do you want me to uncap it? No cost, and you should see a near doubling of the upload speed.
 Chris Parr
 Plusnet Staff
Fixes: 160
Re: sloooowwww
The consistency check is now passing, so there's no reason that you shouldn't see your normal speeds again.
Let us know on the upload question and we'll sort that out for you.
 Chris Parr
 Plusnet Staff
fastconnection
Re: sloooowwww
yes please uncap the uload
many thanks chris - helpful as always
all the best!
Fixes: 160
Re: sloooowwww
That's placed for you, you should see the uncap happen on Monday.
 Chris Parr
 Plusnet Staff
