sloooooooooooowwwwwwwwwww speeds lol
weetos
hi
live 200yds from my exchange and im only getting 2-3 mb downstream can you help?
4 REPLIES 4
Fixes: 1,483
Re: sloooooooooooowwwwwwwwwww speeds lol
can you post some more information results of a BT speed test and any stats from your router.
people might have something to go on to help you then.
cakebar
Lol I get about 2.5megas when mine is running good Grin It's dropped to around 150k at the moment because of a spike on the line resetting the router at the exchange or something but I reported it and just waiting on it coming back to life, I can't really watch youtube at the moment Sad
If you're still having problems, I recommend you raise a fault at http://faults.plus.net and the faults team will investigate for you.
jojopillo
Hi weetos,
Your speed seems to be back up now, with your profile at 6500k.
Jojo Smiley
