sloooooooooooowwwwwwwwwww speeds lol
- Re: sloooooooooooowwwwwwwwwww speeds lol
13-05-2011 10:06 PM
hi
live 200yds from my exchange and im only getting 2-3 mb downstream can you help?
Message 1 of 5
(903 Views)
4 REPLIES 4
13-05-2011 10:18 PM
can you post some more information results of a BT speed test and any stats from your router.
people might have something to go on to help you then.
Message 2 of 5
(424 Views)
15-05-2011 10:03 AM
Lol I get about 2.5megas when mine is running good It's dropped to around 150k at the moment because of a spike on the line resetting the router at the exchange or something but I reported it and just waiting on it coming back to life, I can't really watch youtube at the moment
Message 3 of 5
(424 Views)
16-05-2011 9:24 AM
If you're still having problems, I recommend you raise a fault at http://faults.plus.net and the faults team will investigate for you.
Message 4 of 5
(424 Views)
16-05-2011 3:07 PM
Hi weetos,
Your speed seems to be back up now, with your profile at 6500k.
Jojo
Jojo
Message 5 of 5
(424 Views)
