sky on demand wireless connector
- sky on demand wireless connector
20-03-2013 9:47 PM
I am having a problem getting my plusnet router and my sky on demand wireless hub to connect? any one else had this problem or can help?
Re: sky on demand wireless connector
20-03-2013 10:22 PM
20-03-2013 10:56 PM
Im getting nothing from the start? Try'd to join manually also but never got anywhere? Can get on demand working by plugging cable direct from sky box to hub, but not what i want to be doing
20-03-2013 11:13 PM
Have you made sure the broadband is turned on?
Is your Sky+ box's broadband network connection turned on?
Quote Using the Sky remote, press the services button.
Press the select button.
Press the left/right arrow buttons to highlight Customise.
Press the down arrow button to highlight Broadband Network Connection.
Press the left/right arrow buttons to change the setting to On.
Press the green button to save the settings.
And, then:
Quote Follow these steps to ensure that you have established a connection with your wireless network:
Press the left/right arrow buttons to highlight Settings.
Press the left/right arrow buttons to highlight Network.
Press the select button. You will be shown a list of available wireless networks.
Press the up/down arrow buttons to highlight your wireless network.
Enter your wireless network password using the number buttons on the Sky remote (there's more on how to do this in the "Entering your wireless network password" section below).
Follow the onscreen instructions to save the changes made.
Also, I think you need to make sure the on demand is activated for your box (from the Sky site)
21-03-2013 8:07 AM
See here, http://www.skyuser.co.uk/forum/sky-demand/
I hope you overcome and hope I dont have problems.
21-03-2013 2:29 PM
21-03-2013 2:47 PM
I had on Demand connected before via homeplugs ,but it was on a different fuse box and connection was not very good.
21-03-2013 2:56 PM
What steps have you taken so far? http://www.sky.com/products/__PDF/Wireless_Connector_Set_Up_Guide.pdf
21-03-2013 3:46 PM
I set it up with a fixed ip which worked fine straightaway. After it was connected and I was confident it worked ok I changed it back to dhcp experimentally and it's worked fine since so no idea what the original problem was.
21-03-2013 4:01 PM
21-03-2013 4:13 PM
Are you getting lights on the wifi box? Power should be white, Wireless also white, and ethernet light on the back amber when link is detected (green for fast connection) no light no connection.
Im using Plusnet supplied router (Netgear DGN 2200)
21-03-2013 6:46 PM
21-03-2013 6:51 PM
21-03-2013 7:01 PM
21-03-2013 8:04 PM
