site being blocked and then unblocked - repeat as required
- site being blocked and then unblocked - repeat as ...
17-02-2015 5:34 PM
kickass.to - the infamous torrent site.
now sometimes i am able to access this no problems
other times i have the standard "this site is blocked by court order" page.
both of these could occur in the same day, often within hours of each other
my connection never drops during two results, so is this simply down to different traffic routing at different times of the day?
this is not a debate about the legality (or not) of the site, but rather a query about how it can be unblocked at sometime and blocked at other.
for the record i can currently access it with no problems.
my current gateway is gateway ptw-bng02
Re: site being blocked and then unblocked - repeat as required
17-02-2015 5:39 PM
17-02-2015 5:41 PM
Traceroute has started…
traceroute: Warning: kickass.to has multiple addresses; using 95.215.61.203
traceroute to kickass.to (95.215.61.203), 64 hops max, 72 byte packets
1 dsldevice (192.168.1.254) 1.994 ms 1.336 ms 1.400 ms
2 lo0.10.central10.ptw-bng02.plus.net (195.166.130.203) 25.250 ms 24.419 ms 23.971 ms
3 irb.10.ptw-cr02.plus.net (84.93.249.2) 25.633 ms 24.511 ms 24.027 ms
4 ae2.ptw-cr01.plus.net (195.166.129.4) 24.584 ms 28.035 ms 31.910 ms
5 rou00-blnd01.es.jazztelbone.net (195.66.224.173) 28.361 ms 25.909 ms 27.190 ms
6 141.216.106.212.static.jazztel.es (212.106.216.141) 72.189 ms * *
7 254.216.106.212.static.jazztel.es (212.106.216.254) 150.007 ms 146.232 ms 142.882 ms
8 98.216.106.212.static.jazztel.es (212.106.216.98) 151.257 ms 150.062 ms 151.168 ms
9 2.52.14.62.static.jazztel.es (62.14.52.2) 69.497 ms 73.478 ms 70.072 ms
10 *
17-02-2015 7:26 PM
17-02-2015 10:45 PM
18-02-2015 1:58 PM
18-02-2015 2:12 PM
if an ISP is bound by a court order to block a site then it should be a 100% block and not a block depending on you you happen to be routed at a particular time.
of course, in this instance there is no court order in place against Plusnet, so no court order blocking should be happening at all - but that is another debate entirely.
it would be good if there was a bit of transparency with plusnet on this similar to how sky do it by having a webpage listing the various sites that they have blocked due to court order and when the order was applied.
18-02-2015 2:24 PM
You can see from traceroute that the traffic is going from Plusnet > Jazztel. Plusnet don't chose this route, it happens automatically because it will be the shortest path (AS path). Say Jazztel suddenly stop routing to kickass.to, then Plusnet will change to their next shortest route which might be via BTnet (which is blocking the site).
The DNS records also play a part here because a site like kickass.to will continually be playing around with their hosting.
Edit: Here's an example from me, three traceroutes to kickass.to from the same connection (24 hr apart):
Quote 4 cz-prg01a-ra4-vla2156.net.upc.cz (84.116.221.225) 132.365 ms 105.628 ms 107.433 ms
5 84.116.135.1 (84.116.135.1) 106.964 ms * 109.561 ms
6 uk-lon01b-rd1-xe-1-2-2.aorta.net (84.116.132.17) 106.218 ms 110.055 ms 107.223 ms
7 84.116.133.182 (84.116.133.182) 113.858 ms 106.915 ms 105.564 ms
8 84.116.135.66 (84.116.135.66) 107.071 ms 106.556 ms 129.820 ms
9 bx1-newyork83_pos5_2.net.bell.ca (64.230.187.13) 105.277 ms 121.107 ms 107.303 ms
10 newcore2-newyork83_xe4-2-0.net.bell.ca (64.230.187.157) 139.053 ms
newcore2-newyork83_xe4-1-0.net.bell.ca (64.230.187.161) 143.798 ms
newcore2-newyork83_xe4-2-0.net.bell.ca (64.230.187.157) 132.268 ms
11 tcore3-montreal02_pos0-13-0-0 (64.230.187.237) 122.018 ms
tcore3-montreal02_po0-6-0-0.net.bell.ca (64.230.187.130) 118.512 ms 114.164 ms
12 dis53-montreal02_hundredgige0-2-0-0.net.bell.ca (64.230.91.19) 141.494 ms 117.021 ms 118.293 ms
13 204.101.4.238 (204.101.4.238) 138.982 ms 127.459 ms 129.999 ms
14 v3950.ak1c.800sq.as10929.net (209.44.125.53) 115.412 ms 118.706 ms 113.599 ms
15 68.71.58.34 (68.71.58.34) 120.138 ms 123.665 ms 118.887 ms
Quote 4 cz-prg01a-ra4-vla2156.net.upc.cz (84.116.221.225) 16.137 ms 16.525 ms 16.605 ms
5 84.116.135.1 (84.116.135.1) 38.978 ms 16.277 ms 17.401 ms
6 de-fra01a-ri2-xe-4-1-1.aorta.net (84.116.133.118) 16.725 ms
us-was02a-ri1-ge-4-1-0.aorta.net (84.116.130.206) 16.481 ms
84.116.133.97 (84.116.133.97) 16.384 ms
7 213.46.179.134.aorta.net (213.46.179.134) 16.215 ms 16.052 ms 18.638 ms
8 tenge0-2-0-1.br03.hkg15.pccwbtn.net (63.218.210.142) 333.712 ms 326.874 ms 390.107 ms
9 63-216-142-6.static.pccwglobal.net (63.216.142.6) 409.526 ms 399.181 ms 413.331 ms
10 ae7.bbr02.pn01.hkg01.networklayer.com (50.97.18.175) 405.972 ms 336.560 ms 412.590 ms
11 ae0.bbr02.eq01.sng02.networklayer.com (50.97.18.172) 409.944 ms 363.252 ms 379.686 ms
12 ae6.dar02.sr03.sng01.networklayer.com (50.97.18.203) 409.557 ms 437.346 ms 389.111 ms
13 po2.fcr01.sr03.sng01.networklayer.com (174.133.118.133) 512.557 ms * *
Quote 4 cz-prg01a-ra4-vla2156.net.upc.cz (84.116.221.225) 8.457 ms 8.259 ms 12.051 ms
5 nixcz.retn.net (91.210.16.55) 51.036 ms 26.642 ms 59.906 ms
6 ae3-7.rt.rtc.rix.lv.retn.net (87.245.233.222) 46.956 ms 44.538 ms 52.468 ms
7 gw-baltcom.retn.net (87.245.242.18) 44.739 ms 46.891 ms 45.553 ms
8 * * *
9 telenet-foreign.in.altnet.lv (87.99.79.106) 45.766 ms 45.133 ms 45.742 ms
10 core-48-gw.transit.altnet.lv (195.3.144.14) 49.074 ms 53.395 ms 47.053 ms
The first one routes via Canada, the second via Singapore and the third via Latvia.
18-02-2015 3:31 PM
Quote from: chenks76 it would be good if there was a bit of transparency with plusnet on this similar to how sky do it by having a webpage listing the various sites that they have blocked due to court order and when the order was applied.
If you hit the block this is exactly what you see.
18-02-2015 3:39 PM
that just tells me that the particular website had a court order applied, in this case, to BT due to the routing at that particular time hitting BT at some point.
so that link is actually misleading.
i'm not a BT customer, i'm a plusnet customer, so any court order applied to BT should not apply to any plusnet customer.
just like any court order applied to Sky/Talk Talk/Virgin/EE would also not apply to any plusnet customer.
18-02-2015 3:58 PM
I think you are missing the point here - the court has decided that distribution of the material is illegitimate and is seeks to enforce rights by blocking access. One might argue that facilitating access by another route is a contempt of court.
18-02-2015 4:03 PM
are plusnet in breach of a live court order? if the court order is against plusnet then yes they are.
however, in this instance, the court order is not against plusnet, so they are not currently in breach of any court order as no court has ordered plusnet to block access to the site.
court orders are applied to individual ISPs, i'm not aware of plusnet being the subject of any court order - unless plusnet can show otherwise (hence the transparency).
sky provide access to public webpage that shows the court orders that have been applied to them, the date applied, and the sites affected.
can plusnet do the same?
if they do have an active court order in place to block this particular site then they are in breach of it.
18-02-2015 4:15 PM
If a peer blocks the site, then Plusnet can try and ascertain why that's happening (which they've done in the case of BT). But it's an uphill task given the number of peers/routes etc. It's hard for them to control things once the traffic leaves their network.
18-02-2015 4:18 PM
plusnet are not blocking any sites, but plusnet customers are being pseudo-blocked due to another ISP having one (and it's the ISP not the wholesale side of BT that has the court order).
from what i can see, there is only one peer/route that has this issue, and it's the BT one.
19-02-2015 8:28 PM
Quote from: AndyH If you do a traceroute, does your routing go via BT?
it's blocked again, and this is the tracert
which looks the same as when the site was accessible......
1 dsldevice (192.168.1.254) 2.035 ms 1.646 ms 3.358 ms
2 lo0.10.central10.ptw-bng02.plus.net (195.166.130.203) 124.941 ms 253.908 ms 24.507 ms
3 irb.10.ptw-cr02.plus.net (84.93.249.2) 144.618 ms 25.168 ms 24.873 ms
4 ae2.ptw-cr01.plus.net (195.166.129.4) 25.522 ms 34.312 ms 25.342 ms
5 rou00-blnd01.es.jazztelbone.net (195.66.224.173) 25.360 ms 25.991 ms 33.593 ms
6 * * 141.216.106.212.static.jazztel.es (212.106.216.141) 56.682 ms
7 254.216.106.212.static.jazztel.es (212.106.216.254) 59.081 ms 61.219 ms 55.727 ms
8 98.216.106.212.static.jazztel.es (212.106.216.98) 61.747 ms 62.204 ms 64.125 ms
9 2.52.14.62.static.jazztel.es (62.14.52.2) 77.913 ms 62.022 ms 63.140 ms
10 * * *
11 95.215.61.203 (95.215.61.203) 64.297 ms 61.979 ms 62.065 ms
