should my speed be better ? anyone understand btspeedtest result please
- should my speed be better ? anyone understand btsp...
06-10-2011 6:15 PM
From the bt speed test
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1787 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1787 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :4352 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Re: should my speed be better ? anyone understand btspeedtest result please
06-10-2011 6:17 PM
06-10-2011 6:22 PM
Are you aware of a low sync event
06-10-2011 6:22 PM
2 Mb
06-10-2011 6:23 PM
Quote from: Oldjim Looks correct for the IP profile - which leaves the question why isn't it 3,500kbps
sorry what is a low sync event
06-10-2011 6:25 PM
Do you leave the router on all the time
If you look at the router stats does it give the connected time
06-10-2011 6:30 PM
06-10-2011 6:40 PM
You will now need to wait for a couple of days for the IP profile to increase
06-10-2011 6:45 PM
Quote From checking your account it looks like there may be an issue with your router. I can see a rock solid 28 day connection prior 01:15 this morning, following that there's disconnections every few seconds.
All those disconnections will not have helped. Hopefully the BT profile should increase from 2000 to 3500 in 12 hours.
06-10-2011 6:51 PM
I just wondered if my speed should be faster or set higher than the 2 Mb it is set at
06-10-2011 7:50 PM
Once that change takes place you should see a download speed of around 3100kbps.
06-10-2011 9:09 PM
