should i end up banded within 2 days of training?
bluewhale
and also if i get a new router/modem will btw start training again from scratch?
9 REPLIES 9
scootie
Re: should i end up banded within 2 days of training?
anything is possable with 21cn DLM  Roll_eyes
nope it wont start training off again ( as its 21cn i must add a disclamer to that info thoe  Grin )
what router you currently running on adsl2+ ?
bluewhale
wag54gs
it was ok until a month ago
then things went wrong somewhere, don't know where
and as you know i then got banded, then 2 days ago used my one and only get of jail free card
and now back in jail again
really doesn't seem right, especially as i never got above 6000 profile on the plusnet side of things....
can someone from plusnet explain how this is supposed to work?
bluewhale
anyone fromplusnet have any comments on how dlm works in practice?
scootie
http://community.plus.net/forum/index.php/topic,75667.msg664500.html#msg664500
have read on from this post of mine and gives you an idea how 21cn works it stupid magic  Angry
bluewhale
not really just your own miserable experiences 😉
wonder what has changed, maybe it's my central heating too?
or maybe btw have (down)upgraded the dlm software?
or for the conspiracy theorists this started when adsl2+ went live so maybe a way of keeping bandwidth down, just joking 😉
still with the next router i'll hopefully be able to get more info out of it...
btw whats the link for that router stats program you use and does it work with a netgear  DG834GT ?
dick:quote
Strat
Fixes: 565
This one? http://www.vwlowen.co.uk/internet/files.htm
As to the DG834GT it's on the list Undecided
Well worth a try though Smiley
scootie
nothing to do with outside interference causing the DLM to be stupid on my line, i left my router synced at 12db @ a sync of 3668ish for a full 30days (no reboots no resyncs no droped line)
i said the very same thing when we first learnt of the banding existing, it places it on any line stable or not. so it wouldnt surrpise me if BTw use this to manage bandwidth capicty at exchange level. pretty easy for them to do this and get away with it
bluewhale
well new router setup up the an ex sky netgear DG834GT
so we'll see how we go for now, annoying how i'm stuck down low....
grahamt
To answer the original question - it seems to be quite normal for banding to be reapplied very quickly. The last couple of times my banding has been removed it was reinstated within 2 days. Doesn't seem fair, but that's the way it is.
Graham
