setup linux pppoe with static ip.
- Re: setup linux pppoe with static ip.
21-01-2014 3:42 PM
I've moved from O2/Sky to Plusnet.
I have a static ip number allocated.
How do i configure my linux client ethernet port to work with this ip number.
With my old provider all I did was configure my eth0 port with the provided ip number, gateway, network and subnet mask.
I'm assuming that Plusnet doesn't work that way
Kevin.
Edit. The linux box connects to a Vigor 120.
Kevin.
Message 1 of 5
(2,747 Views)
4 REPLIES 4
21-01-2014 4:37 PM
Which distro of linux?
My setup is:
[ETH0] ------------------ [Modem in bridge mode]
You will need to run pppoeconf (assuming the distro you're using uses that) it will ask you for your username/password, etc. It's pretty straight forward.
If the machine you're talking about is to be your gateway you'll need to enable IPv4 forwarding and MASQUERADE the ppp0 connection using IP Tables.
My setup is:
Message 2 of 5
(895 Views)
21-01-2014 5:27 PM
Distro is Centos 5.6
rp-pppoe and ppp are installed. I already have iptables configured. I assume I just change all occurrences of Eth0 to ppp0
I'm still not sure what happens about my static ip number. Is that assigned after an established connection.
Kevin.
Kevin.
Message 3 of 5
(895 Views)
21-01-2014 5:51 PM
You get your static ip issued by dhcp from PN's radius server.
Message 4 of 5
(895 Views)
21-01-2014 5:59 PM
Thank you.
Message 5 of 5
(895 Views)
