s/n ratio doubled for no reason
qwerty
Hi
Since the trial began I have always  synced between 8 and 10 meg with a s/n ratio of 6db
Except for the last 2 days where it has raised the s/n to 12db and synced at only 6.6meg
lower than my ADSL1 speeds?
1 REPLY
Fixes: 55
Re: s/n ratio doubled for no reason
This seems to be a common trait of the 21CN DLM/MSANs, the "learning" process seems to be much longer than 10 days. Give it a few days and hopefully it will sort itself out, it might even try you on a 3dB target SNR Margin.
David
David
