routers? which is best?
- routers? which is best?
- « Previous
- 1
- 2
- Next »
Re: routers? which is best?
15-01-2011 2:55 PM
Quote from: backtogeek My stats are:
ADSL Link Downstream Upstream
Connection Speed 2272 kbps 448 kbps
Line Attenuation 62.0 db 31.5 db
Noise Margin 3.7 db 19.0 db
My line is 5.6 km from the excahnge
I use a very short 10cm high quality phone cable, no extensions in the house, router allways in the test socket and an ADSL Nation Pro microfilter.
Currently on a Netgear DG834G V4 with DGTeam firmware + SNR tweak
My house is only yards from the cabinet so that helps
IP Profile now at 2000
With the thompson router and none of the advove additions I was syncing at 448up/984down and on an IP Profile of 750
My line is pushed to the limit and stability so far is ok I can do other things to get it syncing around 2850 but its unstable.
think i am going to tinker with my network when bt is done with there test as i have 1m cable from test socket to router using bts adsl filter as i loose 0.3mb if i use thompson supplied one, plus high quality short cable may get me a little extra, whats an snr tweak?
jim:green quote fixed
Re: plusnet replacement for thomson TG585v8 any ideas
15-01-2011 3:03 PM
another forum discussion on the hub give insight on firmware etc
http://community.plus.net/forum/index.php?topic=72671.msg574987
hope this link helps as it for the 2.0 but may be what your looking for as oprateing systems are similar:)
http://bt2700hgv.tripod.com/ir1002700HGVplusnethomehub.htm
15-01-2011 6:57 PM
Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 4032 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.8 17.0
Attn(dB): 61.0 29.5
Pwr(dBm): 19.4 11.9
Max(Kbps): 4384 912
Rate (Kbps): 4032 448
16-01-2011 1:10 PM
16-01-2011 2:50 PM
BusyBox v1.16.1 (2010-05-15 15:58:54 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# adslctl info --vendor
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 0
Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 4160 Kbps
ChipSet Vendor Id: TSTC:0x 0
ChipSet VersionNumber: 0x 0
ChipSet SerialNumber:
The downstream sync rate is higher than before because I rebooted the router 20 minutes ago
16-01-2011 3:17 PM
And I've no idea how you know what chipset the DSLAM has!
16-01-2011 6:39 PM
As for the chipset in the DSLAM that comes from a telnet [color=red]command suitable for the Netgear DG834GT once the busybox is opened.
Enter 'help' for a list of built-in commands.[/color]
[/color]
16-01-2011 7:07 PM
You dont need to be a geek to setup the Draytel 2710.
The wireless range a round the house is great I get 5 bar's in my kitchen which my Speedtouch had no bars plus the 2710 has n which is great for my laptop. It not dropped a connection in 333:50:54
Theirs a usb socket to setup a hard drive or/and a usb printer which makes them act as they are on a network
its not cheap buying draytel products
puddy
16-01-2011 7:14 PM
16-01-2011 8:08 PM
Quote from: Apprentice For my line and its connection to the exchange I find the Netgear DG834GT router which is wired to the PC to be the best I've tried so far, mainly due to the DGTeam firmware and some SNR tweaks. Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 4032 Kbps
Mode: G.DMT
Channel: Interleave
Trellis: ON
Training Status: ShowtimeDown Up
SNR (dB): 6.8 17.0
Attn(dB): 61.0 29.5
Pwr(dBm): 19.4 11.9
Max(Kbps): 4384 912
think you should work for bt as thing aint got a clue and i have same attenuation as you and i only sync at 3000mb and get 2.6mb at best
- « Previous
- 1
- 2
- Next »
