router password
- Re: router password
router password
24-03-2013 8:14 AM
Hi
I'm new to the Plusnet community and so far everything looks good.
I have tried logging in as admin to the plusnet technicolour router to check some settings. I have used the username and password as supplied with the router, taking care to note the case sensitivity; username = admin and password is the serial number. After numerous attempts i can't access the router - is this a probelm for the helpdesk or is there any known fix via the forum?
I'm trying to up the WiFi browsing speed. If hardwired to the router i get 71Mb but wireless drops to 42Mb.
Thanks all
Thanks all
Message 1 of 6
(1,244 Views)
5 REPLIES 5
Re: router password
24-03-2013 8:54 AM
Typical Technicolor passwords begin 'CP' followed by a string of numbers and letters. Omit any trailing symbols. It's not a bad idea to write out the password in a text editor (like Notepad) so you can see it is correct then copy and paste it to the login Window. On a PC you can use Ctrl and v to paste.
Message 2 of 6
(765 Views)
Re: router password
24-03-2013 10:41 AM
I am having exactly the same problem (amongst others)
Message 3 of 6
(765 Views)
Re: router password
24-03-2013 11:13 AM
Hey Roamingrich,
Just a thought - Is your wireless device that you're using Wireless G or Wireless N? If it's wireless G, that might explain it as the max you'll get including overheads is about 54Mbps.
Changing the wireless channel might improve things, but it's ultimately down to the wireless adapter too.
Hope this helps,
Matt
Hope this helps,
Matt
Message 4 of 6
(765 Views)
Re: router password
25-03-2013 12:08 PM
Hi roamingrich,
Have you managed to access your router interface yet?
I've dropped you a PM.
Chris
Chris
Message 5 of 6
(765 Views)
Re: router password
25-03-2013 1:33 PM
Thanks Chris - the 802.11 g or n was exactly the reason for wanting to access the router and ensure it is set for best speed.
Thanks for the PM's and the help - i'll check that out tonight and let you know
Message 6 of 6
(765 Views)
