reserve ip address range on 2704N router
- Re: reserve ip address range on 2704N router
08-02-2016 6:15 PM
Hi, how do you reserve an ip address range on the PlusNet 2704N router? I need a few devices at known addresses then the rest can go with DHCP..
Message 1 of 3
(2,830 Views)
2 REPLIES 2
08-02-2016 7:35 PM
I think I just found the answer, so for anyone else struggling with the crippled router.
Very helpful post from Eva:
Some additional options e.g. turn DHCP on/off, limit DHCP address range, reserve addresses and some other things are available via the Sagemcom GUI i.e.
http://192.168.1.254/expert_user.html
Original Post: http://www.ispreview.co.uk/index.php/2015/01/isp-plusnet-launch-faster-hub-zero-2704n-broadband-rout...
09-02-2016 6:39 AM
Just to confirm, it worked fine. I changed the address range on the lan tab and added the devices with fixed ip's that I wanted.
For info when I chatted to Plusnet support they said their router doesn't do it.
Message 3 of 3
(2,523 Views)
