turn on suggestions
request to uncap upload on adsl2+
- request to uncap upload on adsl2+
06-01-2014 7:58 PM
Migrated today from talktalk LLU to plusnet unlimited; so far, so good!
I see that the upload appears to be capped to 448 kb/s, and that it can be uncapped?
Current sync is (down/up) 18777/445 kb/s, with 19.0/12.4dB attenuation and 6.0/26.4 dB SNR margin, so there should be a bit of headroom - those are similar stats (bar the upload sync) I've had for a long time on talktalk, as it's a fairly short line. Tested with another router just to make sure.
If it can be uncapped, that would be lovely, thanks!
1 REPLY
Re: request to uncap upload on adsl2+
07-01-2014 9:56 AM
