random dropouts
Fixes: 387
Re: random dropouts
@Andrew12 Very sorry to hear this, My apologies for asking for more information, but could you once again post the Help Desk info, and the WAN log. Sounds like this needs re-raising to BT/OR, and having documented evidence may help Plusnet push it.
Andrew12
Re: random dropouts
Hub info:
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ01336885
3. Firmware version: Software version 4.7.5.1.83.8.289.1.3 Last updated 23/11/21
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:18:46
6. Data rate: 9421 / 36519
7. Maximum data rate: 9690 / 36552
8. Noise margin: 6.2 / 6.0
9. Line attenuation: 26.0 / 20.0
10. Signal attenuation: 25.8 / 18.0
11. Data sent/received: 10.1 MB / 387.0 MB
12. Broadband username: @plusdsl.net
13. 2.4 GHz Wireless network/SSID: PLUSNET-FX97
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-FX97
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 64:66:24:d7:57:86
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
BT checker:
Telephone Number on Exchange RETFORD is served by Cabinet 11
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper
High Low High Low
VDSL Range A (Clean) help 67.1 46.5 16 10.2 40 Available Available --
VDSL Range B (Impacted) help 65.8 43.8 15.7 9.3 35 Available Available --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 50 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 1 -- 1 to 3 Available --
ADSL Max Up to 0.75 -- 0.75 to 2.5 Available --
WBC Fixed Rate 1 -- -- Available --
SOADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) WBC SOADSL Availability Date Left in Jumper
WBC SOADSL 2+ Up to 1 -- 1 to 3 -- --
SOADSL Max Up to 0.75 --   -- --
SOADSL Fixed Rate Up to 1 -- 0.75 to 2.5 -- --
Observed Speeds VDSL
Max Observed Downstream Speed 34.29
Max Observed Upstream Speed 10.06
Observed Date 2022-08-23
Other Offerings Availability Date
VDSL Multicast Available
ADSL Multicast Available
Premise Environment Status
Bridge Tap U
VRI --
NTE FacePlate --
Last Test Date 02-07-2022
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal N
SOADSL Restriction Y
speed check attached
Moderators Note
Post released from auto spam filter
Fixes: 387
Re: random dropouts
@Andrew12 Thanks for that - again, it points to an xDSL (BT/OR network) error - the connection is failing outside your property.
If you can post the WAN log from the Event log drop-down as soon as possible - I'm unavailable tomorrow and won't be around much for the next fortnight - that will prove my point.
