"isolated" connection
Something odd keeps happening. I just loose connection to the internet, Well sort of. The router stays connected but it just seems to be connected to nothing because nothing is browsable or pingable or anything. I have to shutdown the router and restart it and then it usually works. Today has been particularly bad
1 REPLY
Fixes: 59
Re: "isolated" connection
I had that with my Netgear DG834G v4 but a firmware upgrade fixed it
