"Unknown" gateway
- "Unknown" gateway
Re: "Unknown" gateway
09-02-2010 5:44 PM
I'm on pcl-ag04
It's a shame you can't force yourself on a particular one ?
09-02-2010 7:35 PM
09-02-2010 8:25 PM
I did it twice today about 1pm - and my speed is still the same - a solid 6.5M
09-02-2010 9:18 PM
This only disconnects you from Plusnet and NOT BT so will not affect your internet connection. This is how other more experienced members have explained it to me in the past.
09-02-2010 10:58 PM
09-02-2010 11:25 PM
What won't be seen as a disconnection will be using the Set Up Wizard or Set Up and applying your Basic Settings (password and stuff), which may or may not find you reconnecting to a different gateway.
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
10-02-2010 8:28 AM
1. From the Browser access the Router
2. From the "Router status" page select "Connection" button at the bottom of the page
3. Select "Disconnect" and wait, then select "connect".
Does that seem right ?
10-02-2010 9:41 AM
19-02-2010 8:28 AM
Quote from: MacOS10 Sorry, I'm on a Mac, don't know how you do a traceroute - or if you can!
Just launch Network Utility from Applications/Utilities.
19-02-2010 9:19 AM
over a maximum of 30 hops:
Just to add a touch of the surreal to this thread - I got the "unknown" gateway on the plus page and when I did a tracert I even got it in there too!
Looks like some wag has set it up in DNS as "unknown" now
1 2 ms 2 ms 1 ms 192.168.101.1
2 29 ms 26 ms 27 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 27 ms 26 ms 26 ms unknown.plus.net [84.92.4.160]
4 27 ms 26 ms 27 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 28 ms 27 ms 26 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 45 ms 27 ms 26 ms 212.58.238.149
7 27 ms 25 ms 27 ms 212.58.239.62
8 27 ms 28 ms 38 ms 212.58.251.43
9 29 ms 33 ms 29 ms fmt-vip04.telhc.bbc.co.uk [212.58.244.143]
Trace complete.
Martin
19-02-2010 9:39 AM
traceroute to 212.58.239.25 (212.58.239.25), 64 hops max, 40 byte packets
1 192.168.1.1 (192.168.1.1) 2.233 ms 1.072 ms 0.857 ms
2 lo0.plusnet.thn-ag2.plus.net (195.166.128.93) 16.631 ms 10.970 ms 20.451 ms
3 unknown.plus.net (84.92.4.160) 27.293 ms 10.406 ms 21.121 ms
4 te2-3.thn-gw2.plus.net (212.159.1.58) 16.090 ms 11.052 ms 12.725 ms
5 * * rt0.thdo.bbc.co.uk (212.58.239.25) 11.706 ms
(Sorry it's not all neat and tabbed, but that's how it comes out when pasted in from Mac's Network Utility)
19-02-2010 9:41 AM
C:\Documents and Settings\bpullen>nslookup 84.92.4.160
Server: 125.structure.internal.plus.net
Address: 84.93.217.125
Address: 84.92.4.160
There's still a few that don't have any rDNS though:
Tracing route to mail.plus.net [212.159.8.81]
1 1 ms 2 ms 4 ms gateway.anfield [192.168.1.254]
2 29 ms 26 ms 29 ms lo0-homesurf.pcl-ag04.plus.net [195.166.128.135]
3 27 ms 26 ms 27 ms 84.92.0.236
4 25 ms 27 ms 27 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 25 ms 25 ms 27 ms vl22.thn-gw1.plus.net [212.159.4.3]
6 29 ms 25 ms 26 ms te3-2.ptn-gw01.plus.net [212.159.1.53]
7 37 ms 37 ms 38 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
8 39 ms 38 ms 37 ms vlan7.pih-gw3.plus.net [212.159.0.26]
9 37 ms 39 ms 36 ms if25.pih-lb04.plus.net [212.159.0.18]
10 37 ms 39 ms 37 ms mail.plus.net [212.159.8.81]
Trace complete.
This will be sorted once the bulk of the expansion work is complete.
22-02-2010 5:42 PM
"The tool currently could not identify your gateway, it does not mean that anything is wrong".
The gateway will become 'known' as network DNS entries are added, but hope the message provides some reassurance in the meantime.
David
22-02-2010 6:05 PM
Quote from: MacOS10 So, after a slight speed drop tonight, I checked to see which gateway I was connected to....
Quote Which gateway
You are currently connected to the "unknown" gateway.
Bit odd, has anyone else noticed that on this page: http://usertools.plus.net/@gateway/
Yes. I saw the same earlier today (and reported it here somewhere!)
Note that I'm on an ordinary connection, not ADSL2+.
25-03-2010 3:59 PM
We created the rDNS entries for the recently installed network kit the other day so I'm kind of hoping this 'unknown gateway' issue is now fixed. Would appreciate it if people could shout up if it's not?
