"This site can't provide a secure connection" error
busylizzie
I have started getting this error when going to the Plusnet home page - only in Chrome. Every other web page I use is fine.
10 REPLIES 10
Fixes: 334
Re: "This site can't provide a secure connection" error
@busylizzie This is the third time I've seen this reported 'error' in the last month, and the common link between them all is the Chrome browser. Which OS are you using (W10/W11), and do you have an alternative browser to try? Plusnets certs are perfectly OK, I'm suspecting a browser configuration error or something wrong in its certificate store.
busylizzie
Windows 10. I could use FireFox (or Edge) but prefer Chrome. It's a "non problem" as it isn't affecting other websites or even PlusNet.
Fixes: 334
I think I understand what you are saying, but it is a problem - in the core of that browser.
bobpullen
Fixes: 327
For those having problems, I'm curious to know what your browser user agent string is? You can check it here.
busylizzie
To summarise: Chrome 116.0.0.0 on Windows 10 (NT 10.0)
gold_finch9
Hi Busylizzie,
I`m getting the same problem as yourself just from today Monday 4th of September, I think it was working last night ok, yes I can use Microsoft edge to get on plusnet I`ve got windows 10 64 bit, I`ve just updated chrome on my settings makes no difference and get the same secure connection " error appear, chrome is normally reliable.
gold_finch9
My browser agent is 116.0.5845.141(official build) (64 bit)
jgj18
I've been having the same problem for the past couple of weeks, using up-to-date Chrome on both my W10 laptop and my Android phone. It works fine under MS Edge, but I don't normally use that. All other websites that I use are fine under Chrome.
gold_finch9
Hi jgj18
What difference it makes long term we`ll have to wait and see but I sent a message to google relating to this I know I won,t get a follow up reply which they state at the time you enquire, but they will follow up such enquiries to see what they can do  meanwhile to try and fix any problems, I noticed on googles website community forum somebody had got these same Issues as we have on here but I`m unclear who their broadband provider was but either way they were trying to use chrome.
Mav
Fixes: 518
Forum Moderator and Customer
