"Router delivery failed - address missing flat number".
Lee13
Our delivery failed because it said invalid address. We live in a block of flats and when i checked the order it changed my address number to the entire set of flats so a delivery couldn’t be made. So we need to give someone an address number.
6 REPLIES 6
MichaelD
Re: "Router delivery failed - address missing flat number".
Hi @Lee13
Welcome to the community.
The best way to get the order updated would be to contact our customer service team. They will be able to bring up your account and order to see if they can get the correct flat number on the parcel, or if they need to arrange for another router to be sent with the correct full address.
Michael
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Broadband to My Account/Billing.
Forum Moderator and Customer
bobpullen
Fixes: 331
Care is needed here. Due to the way the systems work, any comma on an address line is converted to a hyphen before it gets to the warehouse. Depending on what is spat out, it could lead to a situation where the resulting label is indecipherable to a postal worker.
@Lee13 - you could do worse than mention this to support when you speak to them, and ask that they ensure the address is formatted correctly on the hardware order (preferably without any commas) before it's submitted.
AyToZed
A small observation.
When I log into my account via the member Centre my address appears to be correctly represented.
However when I look at the generated bills the address is rather different.
Therefore I must assume that there are two separate databases.
Champnet
Fixes: 21
I'd have thought these were relational databases therefore the output woud be the same which ever way you extracted info.
AyToZed
On (closer) review it appears that my full address appears on my account details. However, the address on the bills (online .PDF) omits the road/street name. Whether that would or could affect a package delivery in any way is unknown. It could be the same rdb, but with different selection criteria.
