("Included") Webspace Usage....
- Re: ("Included") Webspace Usage....
04-08-2009 11:03 AM
I deleted more, but because I'm regularly adding new stuff, I’m having to delete old stuff as I go along. The AUP email states that “further infringements may result in your webspace being restricted, or even removed.” – I don’t want this to happen, and will regularly delete stuff to get back within limits, but when you want to put new stuff up, sometimes it’s a bit onerous to do the house-keeping there and then - so I was just wondering 1/ how regularly/when the script to check space used is run (as it certainly doesn’t seem to be every day), and 2/ just how stringent the limits are (not being “warned” when 5MB over, but being warned when 24KB over, seemed weird….).
Basically, my aim is (of course) to stay within the 250MBytes limit, but I’d rather only do housekeeping once a week, or fortnightly….. (but don’t want my webspace deleted in the meantime).
Thanks,
04-08-2009 11:08 AM
The limit for total capacity is, as you say, 250MB but the allowed bandwidth allowance is as shown here - at the bottom http://www.plus.net/support/webspace/tips_and_info/webspace_faq.shtml#9
04-08-2009 11:28 AM
04-08-2009 12:21 PM
It is worth noting that storage will be allocated in blocks - probably of 4Kbytes.
If you just add up the size of the files then this will be different from the spaces allocated.
Especially if you have a large number of small files.
04-08-2009 12:24 PM
04-08-2009 12:32 PM
04-08-2009 12:35 PM
Quote from: pierre_pierre and that is penguin or $
Well - it's very neat and works in $ and penguin
04-08-2009 1:14 PM
P.
04-08-2009 1:28 PM
Traffic can be a nightmare if you have something interesting and open to the Public, one of our members had a photo of an airbus in an odd place, Google found it and Bang it was the first item on Google search, used all his allowance in a couple of days
04-08-2009 1:36 PM
There is a huge library of photos/videos - hence the high traffic doing that.
