"Access Key" Printed on Thomson Gateway Router
- Re: "Access Key" Printed on Thomson Gateway Router
01-08-2013 6:14 PM
I've just had my BB activated today and everything went like a dream. I just have one question.
I noticed an 8-digit code on the router called an Access Key. It is NOT the WPA Security Key and it is NOT the Password to logon to the Router.
Maybe a clue is that my laptop seemed at ask for this code when I first tried to connect on wireless. However, it gave me another option to use the WPA Security key instead, so I used that...
Any ideas what this is?
Message 1 of 5
(2,346 Views)
4 REPLIES 4
01-08-2013 6:21 PM
Is it all numbers? Maybe it's the WPS pin, but it would be more secure to disable WPS (WiFi Protected Setup) entirely.
Message 2 of 5
(1,069 Views)
01-08-2013 6:28 PM
Mine's not all numbers but I thought it was probably the WPS pin
Message 3 of 5
(1,069 Views)
01-08-2013 7:29 PM
Thanks for the replies!
It is 8-digits - upper case letters and numbers.
Maybe you are both right...
Message 4 of 5
(1,069 Views)
02-08-2013 10:39 AM
Message 5 of 5
(1,069 Views)
