question/info for jojo
niko
hi there
i seem to remember you posting in a thread (i cant find it at the moment)
that if the profiles on 21cn were not on the 88.2 system it needed to be raised as a fault and to let you know
since ive been on 21cn i have only had 20cn profiles (2000 and 2500),
the plusnet side of things has had 21cn but not mine
btspeed test has never given me a 21cn profile
at the moment i should have a 2900 profile but infact i am on 2000
cheers nik
47 REPLIES 47
niko
Re: question/info for jojo
just found it
it seems bt do want this raised as a fault
http://community.plus.net/forum/index.php/topic,99938.msg846806.html#msg846806
Reply #12 on 15/11/2011, 08:22 »
niko
adding screenshot to show old style  rounded  profile
niko
hi again ive gone though the fault checker as i was asked on my ticket ,
it seems a bit daft as this is an exchange problem that your suppliers have asked to to let them know about
jojopillo
Hi niko,
The post you highlighted may well be the same, but I suspect it's something else, like the bRAS or MSAN not updating correctly since your changeover. In order to investigate it further, I'm going to have to raise a fault to our suppliers and then contact them to check the bRAS/MSAN. If it can't be resolved at that level I'll have to raise a case - and that's not the quickest of processes. I'll let you know how I get on.
Jojo Smiley
niko
cheers jojo ,
look forward to hearing back from you
if it was bras problem would it not just be slow rather than rounded?
and by msan do you mean a faulty card?
jojopillo
I think it will be that you still have the profile from 20CN and that it should change when it updates. The MSAN is Multi-Service Access Node which you are connected to at the exchange. Smiley
niko
cheers jojo
sorry but my profile has changed three times already since going on to 21cn so its not that
i believe the msan still has line cards ?but this doesnt seems like a faulty card symtom to me
the fact that its only had 21cn at the exchage 2 weeks i still think its the same problem as that other thread (software update needed for msan)
  thanks again for the update nik
jojopillo
HI niko,
I see our faults team have this in hand.
Jojo Smiley
niko
cheers jojo
hopefully it gets sorted quickly
nik
niko
hi jojo
could you take a look at my ticket and tell me whats going on please
cheers nik
jojopillo
Hi Nik,
I'll ask one of the faults team to check for an update for you.
Jojo Smiley
niko
cheers jojo
thants great
niko
jojo
faults team said its sorted
it isnt nothing has changed ,i still have a 20cn profile on 21cn (still 2000)
it seems there treating it as a stuck profile ,thats not the problem
(well not the only one)
could you please look into this
cheers nik
niko
bt speed test result from 9.08 today
