query re upload speed & why it might have slowed
rhinocratic
Hi everyone
This is not a complaint I'm just perplexed as to cause  Smiley
I'm pretty sure my upload speed used to be above 300kbps.  I don't often check speeds because we've so rarely (touch wood) had a problem. But a month or two ago it took ages to upload files to dropbox  and a speedtest showed upload speed was below 100kbps.  On every speed test since then the upload speed has been between 94-146kbps.
It hasn't bothered me because I don't upload very often but I'm intrigued as to why it is so low when the download speeds are consistently in excess of 6500kbps which is adequate for our needs.
Forgot to add Plusnet's line speed:
Estimated line speed:
Current line speed:
7.15 Mb
Will new filters make a difference?
Thanks for reading.
Here's the Thomson router stats
Uptime: 16 days, 5:31:37
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,008 / 9,536
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 52.11
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 9.0 / 20.5
SN Margin (Up/Down) [dB]: 23.0 / 12.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 720,889 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 786,477 / 0
FEC Errors (Up/Down): 21 / 434,858
CRC Errors (Up/Down): 15 / 13,261
HEC Errors (Up/Down): 9 / 64,121
Fixes: 62
Re: query re upload speed & why it might have slowed
This is a pure guess but have you tried disabling your anti virus as it might be scanning all the uploaded files
Fixes: 4
Is there any p2p software running in the background using 200Kbps of your upload bandwidth ?
rhinocratic
Thanks for replying
I'll try disabling antivirus next time
I don't think it can be p2p as we don't  use (or know how to use) p2p
Cheers
Fixes: 4
What does http://www.speedtest.net/ say your upload speed is ?  Huh
Fixes: 16
What model of router is it? There was a problem with slow uploads over wifi on the 585v8 which was never fixed.
If the 720,889 number of loss of signal errors is accurate, then that's a terribly high number.
rhinocratic
@purleigh speedtest.net result:    Ping 51 ms.  Download 6.74 Mbps  Upload  11 Mbps
@ejs  Thanks for the link. I wonder if you have found the cause.  My router is the TG585 v8  firmware version 8.2.7.8
Fixes: 62
that speedtest result doesn't make sense
regarding the router causing it - can you try wired as that effect was only on wireless
rhinocratic
@Oldjim sorry upload should read 0.11 MBps.  I'll try wired & repost results.
Cheers
rhinocratic
Speedtest wired results: Ping 31 Ms Download 6.76 Mbps Upload 0.36 Mbps
Looks like it is the router  Sad  But on the bright side the 300kbps wasn't my imagination  Cheesy
Buy a new router or use the cable when uploading photos? Decisions, decisions.
@ejs thanks again for  the tip off.
Fixes: 16
You should try different wireless channels (1, 6 and 11 for a start) in case the problem is due to congestion from neighbouring wireless networks, or something else interfering with the wireless signal on your channel.
Fixes: 10
If you are intending to stay with Plusnet for more than a year and your existing router is more than a year old you can have a TG582n from Plusnet for just the P&P (£5.99).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
rhinocratic
ejs & jelv Thanks for your advice.
I'll try changing to a different wireless channel tomorrow when I'm feeling more awake Smiley I don't want to break the internet.
If that fails I may ask plusnet for a new router. This one is approx  two years old.
Cheers
rhinocratic
A brief final update.
The slow upload speed does, as ejs's link suggested,  appear to be the router. I  tried different wireless channels yesterday but no improvement. I also installed inSSIDer and there's no cross channel interference from nearby.
Thanks to all who replied and to ejs for leading me to the cause of the problem.  Smiley
Cheers
