quality monitor
HaydnExport
quality monitor
can you guys take a look at this for me, doesnt look too good to me
http://www.thinkbroadband.com/ping/share/5f6307a70bd87db56cda0300ac957ce4-08-03-2014.html
Fixes: 62
Re: quality monitor
two questions
were you downloading over night and did you have two resyncs or drops of ppp session as that is usually what causes a change in latency
Fixes: 10
Re: quality monitor
Quote from: Oldjim
were you downloading or uploading over night
P2P left running, even if not downloading, could look like that.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
HaydnExport
Re: quality monitor
nothing was running  Sad
HaydnExport
Re: quality monitor
im using a openreach eci modem atm, so i cant see any line stats, errors etc.  Can plusnet staff see these ? i know nobody will be about till monday.  last night's gaming was extremely laggy compared to my bt connection.  Ive tried a different gateway now so ill see if that makes a difference.
HaydnExport
Re: quality monitor
my plusnet ip profile is way higher than my bt one would that make a difference? plusnets is at 78mb and bt's at 60mb
Fixes: 62
Re: quality monitor
Yes it would
That can be a symptom of it
HaydnExport
Re: quality monitor
thanks, i'll ask the staff on monday to have a look at it, just had a very big packet loss spike, then minimum latency has gone down .
HaydnExport
Re: quality monitor
Any chance someone from plusnet can drop my ip profile to match Bt 's please ?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: quality monitor
I've updated the profile for you.
Chris Pettitt
Cloud Environments Engineer
HaydnExport
Re: quality monitor
Cool thanks, I'll check the ping graph after work to see if it's improved.
HaydnExport
Re: quality monitor
Plusnet Alumni (retired) LinnPlusnet
Re: quality monitor
Hi HaydnExport,
I've taken a look for you and there's nothing obvious that stands out. If you continue experiencing any issues then I would advise to raise a fault so that our Faults team can investigate further for you.
HaydnExport
Re: quality monitor
ill try a different modem and a homehub 5 over the next couple of days just to eliminate a hardware issue
HaydnExport
Re: quality monitor
It was my pc, switched it off over night and its flat as anything!  Can plusnet staff see my linestats ?  I had interleaving added as there was a fault ( suposedly fixed) at my exchange.  Am i likely to be taken off by the dlm soon ?
