puzzled by upstream and downstream rates
- puzzled by upstream and downstream rates
29-07-2010 12:41 AM
All of a sudden, the rates I'm seeing reported by my router are not ones that I'm used to seeing.
A week ago, I had an attenuation of -62dB, my downstream rates were all nice even numbers between 1728 and 2272-ish.
My upstream rate was... I think... 448 or something.
Now I'm seeing odd values for the downstream rates, like 1963. And my upstream rate is 450. My attenuation has changed to -65dB on this router and -70dB on another.
I'm at a loss to explain why the values are not as consistent as before. I may just be seeing things, but can somebody explain why these odd numbers have occurred?
Thanks.
-- gyre --
Re: puzzled by upstream and downstream rates
29-07-2010 8:15 AM
29-07-2010 8:35 AM
Can you check with another connecting cable and filter in the test socket
29-07-2010 9:41 AM
Changed wire.
Changed filter and used test socket.
No change in reported values.
Just looks like the overall stats have taken a turn for the worst.
However, my question was more... why the non-even/non-448 numbers as opposed to why have the figures got far worse.
-- gyre --
29-07-2010 9:45 AM
If the upstream is anything lower than 448kbps then this indicates a problem, possibly a voice line fault that's crossing over into the broadband
If the downstream is degrading then this suggests a broadband line fault.
http://faults.plus.net please.
29-07-2010 9:47 AM
Have you been moved to 21CN which will affect the attenuation
Can you post the stats from your router
29-07-2010 10:13 AM
See what you can make of these stats, anyway.
# cat /proc/avalanche/avsar_modem_stats
AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 450 DS Connection Rate: 1999
DS Line Attenuation: 65 DS Margin: 9
US Line Attenuation: 42 US Margin: 10
US Payload : 4334544 DS Payload: 7919472
US Superframe Cnt : 111943 DS Superframe Cnt: 111943
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 4 Severely Err Secs: 1
Frame mode: 0 Max Frame mode: 0
Trained Path: 1 US Peak Cell Rate: 1061
Trained Mode: 16 Selected Mode: 1
ATUC Vendor Code: 54535443 ATUC Revision: 3
Hybrid Selected: 1 Trellis: 1
Showtime Count: 3 DS Max Attainable Bit Rate: 2196 kbps
BitSwap: 1 US Max Attainable Bit Rate: 858270 bps
Annex: AnxA psd_mask_qualifier: 0x0000
Power Management Status: L0 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -366
Total init. errors: 2 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 1 Last showtime init. timeouts: 0
ATUC ghsVid: b5 00 54 53 54 43 05 10
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
CRC: 3 FEC: 735 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 90303
Idle Cell Cnt: 1929423
Tx Packets Dropped Count: 0
Tx Bad Packets Count: 207
[Downstream/RX)]
Good Cell Cnt: 164989
Idle Cell Cnt: 8809768
Bad Hec Cell Cnt: 10
Overflow Dropped Cell Cnt: 0
Rx Packets Dropped Count: 0
Rx Bad Packets Count: 0
[SAR AAL5 Stats]
Tx PDU's: 1421266
Rx PDU's: 2148425
Tx Total Bytes: 161917278
Rx Total Bytes: 3040891578
Tx Total Error Counts: 0
Rx Total Error Counts: 44
[OAM Stats]
Near End F5 Loop Back Count: 0
Near End F4 Loop Back Count: 0
Far End F5 Loop Back Count: 0
Far End F4 Loop Back Count: 0
SAR OAM Ping Response Drop Count=0
29-07-2010 10:31 AM
29-07-2010 10:36 AM
Why it is synching at 450kbps I have absolutely no idea
Note that moving from 20CN to 21CN involves connecting to a different piece of equipment in the exchange which may well affect the reported attenuation
29-07-2010 10:49 AM
Yup, I don't know why the 450. I swear it has always been 448 for years, even when I moved to 21CN.
Actually, when I did move to 21CN earlier in the year, the downstream attenuation went from 63 or 65dB to 62. It has only just shot back up to 65 again.
I have actually synced at over 2300kbps when the target snr margin was 6dB. But it went up to 9dB a while back after using a stupid 2wire modem and has never come down again
-- gyre --
29-07-2010 11:04 AM
adsl info expand=enabled
Modemstate : Up
xDSL Type : ADSL2+
xDSL Standard : ITU-T G.992.5
xDSL Annex : Annex A
Uptime (days hh:mm:ss) : 0 days, 0:03:28
Number of resets : 1
Total Available Bandwidth Cells/s kbit/s
Downstream : 4561 1934
Upstream : 778 330
Bearer Generic Info Downstream Upstream
INP (DMT) : 1.20 2.37
Delay (ms) : 7.93 5.33
R : 10 8
Margin (dB) : 10.0 5.5
Attenuation (dB) : 69.0 42.0
OutputPower (dBm) : 17.0 11.5
Vendor Chipset Local Remote
Country : B500 B500
Vendor : BDCM TSTC
VendorSpecific : 0000 0510
StandardRevisionNr : 00 63
Vendor System
Country : 0F00 0000
Vendor : TMMB ----
VendorSpecific : 3C61 0000
StandardRevisionNr : 00 00
Transfer statistics
Errors
Received FEC : 12
Received CRC : 0
Received HEC : 0
Transmitted FEC : 0
Transmitted CRC : 0
Tranmsitted HEC : 167464
Near end failures since reset
Loss of frame : 0 failures
Loss of signal : 0 failures
Loss of power : 0 failures
Errored seconds : 0 seconds
Near end failures last 15 minutes
Loss of frame : 0 seconds
Loss of signal : 0 seconds
Loss of power : 0 seconds
Near end failures current day
Near end failures previous day
{admin}=
I think I've been moved to ADSL2 somehow.
-- gyre --
29-07-2010 11:13 AM
Your upstream sync had dropped to 330kbps with a noise margin of 5.5dB
29-07-2010 11:18 AM
I was able to force the router to use adsl1, and got the following stats:
Modemstate : Up
xDSL Type : ADSL
xDSL Standard : ITU-T G.992.1
Channel Mode : Interleaved
Uptime (days hh:mm:ss) : 0 days, 0:02:04
Number of resets : 3
Downstream : 5056 2144
Upstream : 1056 448
Margin (dB) : 9.5 14.0
Attenuation (dB) : 63.5 31.5
OutputPower (dBm) : 17.5 12.0
Country : B500 B500
Vendor : BDCM TSTC
Vendor System
Country : 0F00 0000
Vendor : TMMB ----
Transfer statistics
Errors
Received FEC : 8
Received CRC : 0
Received HEC : 0
Transmitted FEC : 0
Transmitted CRC : 0
Tranmsitted HEC : 0
{admin}=
Which looks pretty much what I used to get before the oddities started happening this week.
-- gyre --
29-07-2010 12:12 PM
-- gyre --
29-07-2010 12:19 PM
