public IP address cost?
silvacrest
HI,
I just wanted to know how much a public IP address costs from plusnet?
paulby
Re: public IP address cost?
Do you mean a static IP?
You already have a public IP by the mere fact you're connected to the internet.
If you're on a BBYW package, you can change to a static IP at no cost here (login required) under "Change IP Settings".
silvacrest
On the current package i am on  (option 3)  how much will an additional ip address cost
Silvacrest  Bro
Mcsa/Mcse 2003 system administrator
GeekSquad UK
paulby
The info you need is here, under section 3.
