public IP address cost?
- Re: public IP address cost?
05-03-2008 11:48 AM
HI,
I just wanted to know how much a public IP address costs from plusnet?
Message 1 of 4
(4,043 Views)
3 REPLIES 3
05-03-2008 12:35 PM
Do you mean a static IP?
You already have a public IP by the mere fact you're connected to the internet.
If you're on a BBYW package, you can change to a static IP at no cost here (login required) under "Change IP Settings".
Message 2 of 4
(560 Views)
05-03-2008 12:47 PM
On the current package i am on (option 3) how much will an additional ip address cost
Silvacrest Bro
Mcsa/Mcse 2003 system administrator
GeekSquad UK
Silvacrest Bro
GeekSquad UK
Message 3 of 4
(560 Views)
05-03-2008 12:56 PM
The info you need is here, under section 3.
Message 4 of 4
(560 Views)
