ptw-ag03 is still borked
- Re: ptw-ag03 is still borked
14-08-2013 4:34 AM
Just had to reconnect to another gateway, now I'm on pcl-ag05 and the difference is night and day. Youtube videos play instantly, and I have had any problems in Star Trek Online, or with Raptr.
EDIT: Apparently my ping is higher with this gateway though:
14-08-2013 4:54 AM
EDIT; I have a feeling that video is meant to have a commercial at the beginning which may be causing the long loading as I have google ads blocked.
14-08-2013 7:34 AM
Try hopping to the currently modified gateway PCL-AG02, as that was giving me good latency results last night
and I can view the video mentioned above without issue while on that gateway.
14-08-2013 10:24 AM
14-08-2013 10:26 AM
14-08-2013 11:07 AM
14-08-2013 11:53 AM
Finally made it out of City Lifeline. That's enough for now.
14-08-2013 12:09 PM
Ex-Broadband Service Manager
14-08-2013 12:37 PM
Quote from: Pyrii I've just spent a week on this gateway and it still has problems with slow Youtube loading, random timeouts or slow establishing connections. And iPlayer also buffers a lot on this gateway.
Do you know if it was the worst over the week between about 10:30am and 3:30pm on Tuesday? I'm looking at some quality data for your connection, yesterday it looks OK between midnight and 6am, it little poorer between 6am and 10:30am, then very poor between 10:30am and 3:30pm before improving and then being a bit poor between 8pm and 10pm.
Plusnet Technology
14-08-2013 4:00 PM
