ptw-ag01 problems?
ptw-ag01 problems?
I did a clean reboot of my router at around 2.20 pm and now under constant loss
edit: and not the only one, a few graphs with spikes at the same exact times
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Re: ptw-ag01 problems?
ptn-ag02 more of the same, so another PPP drop to find one that is not falling over
Currently on pcl-ag03 and seems to be back to normal but if you are on ptn-ag02 or  ptw-ag01 expect problems
http://usertools.plus.net/@gateway to find out
