profile unlock
scottymc
profile unlock
Hi guys
I've posted my problems before but with the of the people on the forum they have cleared.
I found that my upload interference was down to my homeplugs well the WiFi extender side of things I turned that off and the interference went . Homepulgs are working fine via ethernet .
But where I was having problems my profile was it seems locked @4544 sync , even thought my down srn is 8/9
Can you guys please reset it before the problems start I was synced @5200/5500 I know this don't sound like a lot but every little helps
Also please leave interleaving off gaming pings are much better with it off
Thank you
Scott
Fixes: 160
Re: profile unlock
The line is banded, so you won't sync higher until that's removed. There's no interleaving on at the moment.
I'm going to remove the banding now.
 Chris Parr
 Plusnet Staff
Fixes: 62
Re: profile unlock
A question
Why is the line banded without interleaving as I thought that banding was only applied after the line was interleaved and that didn't fix it
scottymc
Re: profile unlock
Thank you Chris
I knew it was off just didn't want it to go back on sorry for the confusion
Scott
