profile unlock
- Re: profile unlock
profile unlock
18-06-2015 7:07 AM
Hi guys
I've posted my problems before but with the of the people on the forum they have cleared.
I found that my upload interference was down to my homeplugs well the WiFi extender side of things I turned that off and the interference went . Homepulgs are working fine via ethernet .
But where I was having problems my profile was it seems locked @4544 sync , even thought my down srn is 8/9
Can you guys please reset it before the problems start I was synced @5200/5500 I know this don't sound like a lot but every little helps
Also please leave interleaving off gaming pings are much better with it off
Thank you
Scott
Thank you
Scott
Message 1 of 4
(531 Views)
3 REPLIES 3
Re: profile unlock
18-06-2015 9:28 AM
The line is banded, so you won't sync higher until that's removed. There's no interleaving on at the moment.
I'm going to remove the banding now.
Message 2 of 4
(299 Views)
Re: profile unlock
18-06-2015 9:30 AM
A question
Why is the line banded without interleaving as I thought that banding was only applied after the line was interleaved and that didn't fix it
Message 3 of 4
(299 Views)
Re: profile unlock
18-06-2015 10:15 AM
Thank you Chris
I knew it was off just didn't want it to go back on sorry for the confusion
Scott
Scott
Message 4 of 4
(299 Views)
