problems with pcl-ag08 today?
There was some work by BT last night so wondering if its affecting pcl-ag08 and it needs a rebalance as I have had inbound packetloss since 6.30am.  Everything online is slower or timing out.  Yet to do a gateway hop, but will be to see if it helps
19th September
Sheffield / London Catford / Wolverhampton
edit: did a manual line drop and got ptn-ag02 with the same results and just had a another dropped PPP which I didn't do to pcl-ag06
edit mk2: pcl-ag02 now after a reboot see if it changes
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Re: problems with pcl-ag08 today?
There have been no reported issues and we have checked the gateways and everything appears to be running as normal.
Let me know if your still having issues with yours.
The reboot seems to have cured it, currently on pcl-ag02 and my TBB graph looks healthier plus web browsing is faster
rongtw
Fixes: 12
Tonight I had problems on pcl-ag01  Sad   second time just lately  am on 80/20  gaming has been unable to play  Embarrassed just done a gateway hop will let you know
PS my DL speed has dropped to 57
ag 07 now
Fixes: 5
Did you get a wireshark?
Kelly Dorset
Broadband Service Manager
Fixes: 166
Have a look in here: http://community.plus.net/forum/index.php/topic,107793.0.html
 Chris Parr
 Plusnet Staff
JamesM
Ping is usually 5 ms, was OK early evening but the last few nights BF3 is unplayable.
pcl-ag04.
Fixes: 5
50ms ping shouldn't be unplayable.  Sounds like something else.  Do you know what server your are connecting to.  Can you tracert it?
Kelly Dorset
JamesM
This is happening on every server I try Kelly, I am just stood running on the spot, not being able to shoot or even change weapons. I had a quick go around 5:00PM and I was about 64 for 12, same as Monday I had a quick go early evening and it was fine. it just seems to happen later on. I get the orange triangle with the broken connection. It then goes fine so I can run (just enough to get me out of the uncap)  then it happens again so I can't move.
I was in all day today with the engineer coming in the morning and I have enjoyed seeing speeds I havent had before and my ping has been 5 all day. This happened on the apple launch night, then again on Monday night, and again tonight.
I am getting 42 pinging bbc.co.uk.
No sweat mate, it is just ping spikes, just wanted to let you know here as I can't do any of the other tests that the other thread asks for. I will leave it for a couple of days until all the apple frenzy is over and see how it is.
10:10PM. fine again
rongtw
Fixes: 12
gateway hop sorted it  Wink but its  weird why just lately that between 8 -9 ish problems occur
95% of time its fine . but as usual  the odd 5% we complain about  Roll eyes
Blim
Its because we only use our connection 5% of the time. Most people are at work all day then we all jump online at the same time. For me this problem start just as I start getting some time off after 6 months + of afd'ers. I just hope this isnt going to be a on going thing over the winter as more people start to use the internet and fibre being more connon. Who needs a connection faster than 20mb anyway. just so you do short burst of fast downloading? Realy quite pointless really. Unnecessary stress on the network.
