problems tonite ?
rongtw
Fixes: 12
problems tonite ?
had a disconnect then a terrible connection with a large ping spike , think i was on PCL AG08
am on pcl ag02 now
23 REPLIES 23
Santiago
Re: problems tonite ?
Been crap all weekend for me.Lots of disconnects.
fagin
Horrendous DL and PING here too.
Kelly
Fixes: 9
Can you post your normal speeds and what you are currently getting and also your experiences?  I think we've an issue tonight which may have been running the weekend and I'd like to have examples of what it was causing so I can take that back to look at.
The ping graphs page has about 5 graphs on with packet loss at peak last night and starting tonight, plus quite a few others (20ish?) have tiny bits of packet loss through them I've not noticed happening before.
Kelly Dorset
Ex-Broadband Service Manager
fagin
PING is around 20ms - normally 10ms.
DL speed is around 5 Mbps - normally 50 Mbps (UL is fine).
MODEM stats are fine with normal sync speed attainable and actual.
I'm not sure the speed and ping figures tell the whole story though as it really is laggy (and that Ping is not that bad in reality).
Kelly
Fixes: 9
Can you do a speedtest through: http://speedtest.btwholesale.com/ and paste the results.
Kelly Dorset
fagin
Sure.... as requested.
nokiboi39
Friday was ok for me, however over the weekend marked difference.
Kelly
Fixes: 9
Ok.  Can you open a cmd prompt and run:
ping -n 100 www.bbc.co.uk
and paste the stats in here?   I'm looking for % packet loss :).  Here is my example, and I'm not seeing any issues right now.
Ping statistics for xxxxxx:
   Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 22ms, Maximum = 72ms, Average = 25ms
Kelly Dorset
nokiboi39
Current BT Speedtest showing high latency 42
Download speedachieved during the test was - 49.43 Mbps
For your connection, the acceptable range of speedsis 50.05 Mbps-62.56 Mbps .
Additional Information:
IP Profile for your line is - 62.56 Mbps
Upload speed achieved during the test was - 12.43Mbps
AndyH
nokiboi39 - Which exchange are you on?
You can ignore the BTw Speed Tester latency - I always get high results (even when I am getting 3-4ms bbc.co.uk pings).
@ Kelly - pcl-ag08 did seem to lose a lot of users on it this morning according to the users graph
fagin
    Packets: Sent = 100, Received = 93, Lost = 7 (7% loss),
    Minimum = 11ms, Maximum = 18ms, Average = 12ms
Kelly
Fixes: 9
Quote from: fagin
Yeah. that loss is why you're slow.
Kelly Dorset
fagin
Currently on the pcl-ag01 gateway.
Kelly
Fixes: 9
Disconnect and reconnect and lets see if it improves?
Kelly Dorset
