problems after migration
- Re: problems after migration
31-12-2013 9:36 AM
So I had to ring this morning to get my account activated as I reported my status was stuck.
Now I seem to be capped at 8mbit/sec although the portal reports my line speed at 78mbit/sec.
Also I cannot order a static ip I dont have the addons button available.
Message 1 of 6
(1,050 Views)
5 REPLIES 5
31-12-2013 9:40 AM
Everything on your account is set correctly now, the speed profile isn't going to be restricting you and the line details are correct.
I'll have a quick look and see if there's anything else I can spot.
The static IP add-on is available to you, I've just checked on our side and the link is visible so should be to you here:
https://portal.plus.net/AddOns.html
Message 2 of 6
(640 Views)
31-12-2013 9:44 AM
Ok thanks for the quick reply Chris as I didnt want to be on hold again.
Ordered the static ip.
Purposelly disconnected and recconected my router to activate the static ip.
Aftr I did that speed is fine.
Thanks.
Thanks.
Message 3 of 6
(640 Views)
31-12-2013 9:45 AM
Good to hear, I've just fixed the speed profile on our side as it was too high.
Message 4 of 6
(640 Views)
31-12-2013 9:54 AM
well now its dropped back down again to 8mbit/sec.
It is flatlining there.
--edit--
I manually recconected ppp again and speeds are back up.
--edit--
Message 5 of 6
(640 Views)
31-12-2013 9:59 AM
i have a similar isues
Message 6 of 6
(640 Views)
