postini
- postini
Re: postini
20-01-2008 10:16 AM
Re: postini
20-01-2008 10:44 AM
and you loose mail you should have got
Re: postini
20-01-2008 10:53 AM
OK, but that in itself does not tell one that one is on Postini. It is not evidence. What will be viewable to say that the transfer has been made? I take it that your asnwer was flippant
Quote from: pierre_pierre you stop getting lots of spam, how else?
Re: postini
20-01-2008 11:48 AM
nslookup -type=mx username.plus.com
or
nslookup -type=mx domainname.co.uk
The results from the first will contain "postini", the second will contain something like domainname.s5a1.psmtp.com
Re: postini
20-01-2008 11:54 AM
If you are using Outlook Express right click on the message header (the line displayed in your ‘Inbox’ before you open the message).
From the pop up menu select and click on ‘Properties’
In the small window that opens click the [Details] tab to bring it forward
Check the ‘From:’ lines it should mention something like xxxxxxxmx249.postini.com to confirm if the message was scanned by Postini.
With Outlook 2003 (may work with other versions) proceed as above but select and click ‘Options’ and the header details will be displayed in the next open window at the bottom.
Hope this will help, P.
Re: postini
20-01-2008 3:25 PM
Re: postini
21-01-2008 4:09 PM
Yep the volume of spam has gone down a bit!!
Re: postini
21-01-2008 11:49 PM
Re: postini
22-01-2008 11:54 AM
Quote from: jelv I've seen other posts like this - it looks like something went very, very wrong with the last batch of people who were moved to Postini (something similar has happened previously so how it's happened again... !)
I have been happily using Mailwasher, with settings in PlusNet Manage My Mail having spam filtering off. Spam filtering in Mailwasher has been working just fine and my own filtering system has been very effective, spam emails being deleted automatically and confidently without my ever seeing them. That's been perfectly ok for months, ever since the disastrous email leak at PlusNet happened.
Now I believe my email is being routed (unasked for by me) through Postini - On the 20th, Received: from source ([]) by exprod5mx223.postini.com ([]) with SMTP; - and I also believe I must have lost emails because of this latest happening. As far as I can figure it out I won't be able to check since they will have been deleted on the server by Mailwasher! I have now had to alter all my own spam filtering and will see ALL of the spam, God help me!
I want to receive my email, all of it, as is and not suffer the risk of losing anything important through the repeated errors of others. I do not want my email to be filtered by anyone other than myself.
What, if anything (other than changing ISP) can I do about this? And how can I find out if I've lost mail?
Re: postini
22-01-2008 12:05 PM
Everyone but around two thirds of PN customers and PNUK customers are now on Postini. I can get you removed if you really feel that strongly about it (we'll offer this functionality via the portal soon), but it won't be long before the rbl's, Dspam and Clam are switched off on the old mail platform meaning *everything* will be delivered to you (bear in mind that we blocked some stuff from coming through to you even before the implementation of Postini.
Re: postini
22-01-2008 1:02 PM
I do feel strongly about this and it's very rare for me to post here at all. Prior to the email address leak I was one of those who had been very, very careful with my email addresses and I received very little spam. Afterwards, when spam came flooding in, I found filtering with Mailwasher to be perfectly satisfactory and I did not complain - mistakes do happen, complaining doesn't really help.
It seems that more errors may have resulted in the possible loss of emails and I am. I'm afraid, losing patience since the loss of legitimate emails is in my opinion the worst thing to happen.
I don't know what the effect of switching off rbl's, Dspam and Clam will be on the level of spam received and so I can only express the wish to be removed, if the possibility of errors exist, from Postini filtering and wait and see. I have the Catch-all off which I hope has the effect of refusing all but named mailboxes.
I presume I'm correct in thinking I cannot now find out if I've lost mail?
Re: postini
22-01-2008 9:02 PM
Quote from: tammyd I have been happily using Mailwasher, with settings in PlusNet Manage My Mail having spam filtering off. Spam filtering in Mailwasher has been working just fine and my own filtering system has been very effective, spam emails being deleted automatically and confidently without my ever seeing them.
I've been using a similar system but without Mailwasher automatically deleting emails it deems to be spam: even Mailwasher isn't that good and Firetrust suggest that it's a little risky.
Why not alter it to delete when you click on 'Process Mail'?
Re: postini
22-01-2008 9:27 PM
It wasn't risky to automatically delete spam according to the rules I set and I hope to return to that system, it worked very well indeed. There were always some borderline mails that were simply marked to delete on 'Process Mail'. But very few.
Re: postini
23-01-2008 12:09 AM
Quote from: tammyd I don't know what the effect of switching off rbl's, Dspam and Clam will be on the level of spam received and so I can only express the wish to be removed, if the possibility of errors exist, from Postini filtering and wait and see. I have the Catch-all off which I hope has the effect of refusing all but named mailboxes.
OK, I shall see if I can remove you tomorrow however the change will take 24-48 hours to propagate due to the nature of DNS.
Re: postini
23-01-2008 8:43 AM
Quote from: Bob
Thanks Bob
