postimg.org timing out!
Hi gang,
Yes I know it's been awhile  Wink
I'm having problems reading on another forum that has links to images on http://www.postimg.org/
Most other forumites do not have an issue.
My question is do you have a problem with a timeout and if so is it a possible plusnet DNS issue?
Thanks for taking a look.
Quote....
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: http://s5.postimg.org/
The following error was encountered:
    Connection to 141.101.123.62 Failed
The system returned:
    (110) Connection timed out
The remote host or network may be down. Please try the request again.
Generated Fri, 03 Apr 2015 16:17:20 GMT by pcl-iwfcache04.plus.net (squid)
Another location returned the same error from
"Generated Fri, 03 Apr 2015 16:56:26 GMT by pcl-iwfcache03.plus.net (squid)"
Fixes: 16
Re: postimg.org timing out!
Thanks ejs my search did not pick that one up.
I'll watch both threads with interest.
Cheers
Fixes: 5
I think this says it all:
Tracing route to www.postimg.org [46.229.166.177]
over a maximum of 30 hops:
  1    1 ms    1 ms    1 ms  192.168.1.1
  2    33 ms    36 ms    33 ms  lo0.11.Central11.ptn-bng02.plus.net [195.166.130
.191]
  3    33 ms    34 ms    33 ms  irb.11.PTW-CR02.plus.net [84.93.249.18]
  4    34 ms    33 ms    35 ms  ae1.pcl-cr02.plus.net [195.166.129.3]
  5    53 ms    34 ms    33 ms  po2.pcl-gw02.plus.net [195.166.129.43]
  6    34 ms    34 ms    33 ms  tun0.pcl-gw01.plus.net [212.159.2.105]
  7  flowers2.servers.plus.net.uk [212.159.2.98]  reports: Destination net unrea
chable.
Never seen flowers2.servers.plus.net.uk before.  Undecided
But I can access the site through a proxy server.
http://www.openproxy.co.uk
Apprentice
  1    *        *        *    Request timed out.
  2    74 ms    48 ms    49 ms  lo0-central10.ptn-ag02.plus.net [195.166.128.191]
  3    49 ms    49 ms    48 ms  link-a-central10.ptn-gw01.plus.net [212.159.2.132]
  4    50 ms    51 ms    48 ms  xe-1-2-0.ptw-cr01.plus.net [212.159.0.112]
  5    48 ms    47 ms    49 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6    48 ms    48 ms    48 ms  tun0.ptn-gw01.plus.net [212.159.2.101]
  7    48 ms    48 ms    48 ms  te2-1.gr9.plus.net [212.159.2.110]
  8    50 ms    49 ms    49 ms  195.99.126.138
  9    51 ms    55 ms    56 ms  194.72.31.138
10    49 ms    49 ms    49 ms  core4-te0-10-0-2.faraday.ukcore.bt.net [213.121.193.55]
11    50 ms    50 ms    49 ms  peer2-et-8-3-0.faraday.ukcore.bt.net [62.6.201.197]
12    50 ms    53 ms    53 ms  213.137.183.102
13    50 ms    50 ms    50 ms  t2c3-xe-1-3-2-0.uk-lof.eu.bt.net [166.49.237.28]
14    50 ms    51 ms    50 ms  t2c3-xe-11-0-2-0.uk-lon1.eu.bt.net [166.49.208.18]
15    55 ms    50 ms    50 ms  tge2-1-506.edge1.lon2.uk.as5580.net [195.66.237.111]
16    51 ms    50 ms    50 ms  eth3-7.core1.lon1.uk.as5580.net [78.152.44.162]
17  134 ms  134 ms  135 ms  eth4-2.core1.nyc1.us.as5580.net [78.152.44.135]
18    *        *        *    Request timed out.
19  139 ms  146 ms  149 ms  eth2-3.r1.ash1.us.as5580.net [78.152.35.41]
20  137 ms  137 ms  136 ms  78.152.46.202
21  136 ms  136 ms  135 ms  46.229.166.177
Trace complete.
Looks like my ADSL1 taxi took the tourist route just now Grin
Fixes: 58
There is something odd going on with that site
http://www.postimg.org/ redirects to http://postimage.org/
and either goes right round the houses
Tracing route to postimg.org [46.229.166.177] over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  dsldevice.lan [192.168.1.254]
  2    38 ms    37 ms    33 ms  lo0-central10.pcl-ag05.plus.net [195.166.128.186]
  3    33 ms    33 ms    32 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.176]
  4    33 ms    60 ms    31 ms  xe-1-2-0.pcl-cr01.plus.net [212.159.0.208]
  5    34 ms    33 ms    32 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  6    32 ms    32 ms    33 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  7    33 ms    32 ms    32 ms  tun0.ptn-gw01.plus.net [212.159.2.101]
  8    32 ms    32 ms    32 ms  te2-1.gr9.plus.net [212.159.2.110]
  9    34 ms    34 ms    33 ms  195.99.126.138
10    36 ms    39 ms    39 ms  core2-te0-0-0-10.ilford.ukcore.bt.net [109.159.254.133]
11    34 ms    34 ms    34 ms  core4-te0-19-0-3.faraday.ukcore.bt.net [213.121.193.45]
12    33 ms    33 ms    33 ms  peer2-et-10-3-0.faraday.ukcore.bt.net [62.6.201.199]
13    34 ms    36 ms    33 ms  213.137.183.98
14    33 ms    33 ms    34 ms  t2c3-xe-1-3-3-0.uk-lof.eu.bt.net [166.49.237.72]
15    33 ms    34 ms    33 ms  t2c3-xe-1-0-2-0.uk-lon1.eu.bt.net [166.49.208.16]
16    35 ms    43 ms    35 ms  tge2-1-506.edge1.lon2.uk.as5580.net [195.66.237.111]
17    35 ms    37 ms    35 ms  eth3-7.core1.lon1.uk.as5580.net [78.152.44.162]
18  119 ms  118 ms  118 ms  eth4-2.core1.nyc1.us.as5580.net [78.152.44.135]
19  124 ms  123 ms  126 ms  eth3-1.core1.ash2.us.as5580.net [78.152.45.193]
20  124 ms  123 ms  124 ms  eth2-3.r1.ash1.us.as5580.net [78.152.35.41]
21  121 ms  120 ms  121 ms  78.152.46.202
22  115 ms  115 ms  116 ms  46.229.166.177
Trace complete.
C:\Users\Jim>tracert postimage.org
Tracing route to postimage.org [46.229.168.33]
  2    34 ms    33 ms    35 ms  lo0-central10.pcl-ag05.plus.net [195.166.128.186]
  4    32 ms    32 ms    32 ms  xe-1-2-0.pcl-cr01.plus.net [212.159.0.208]
  5    33 ms    32 ms    36 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  6    33 ms    32 ms    32 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  7    33 ms    32 ms    33 ms  tun0.ptn-gw01.plus.net [212.159.2.101]
  8    33 ms    33 ms    32 ms  te2-1.gr9.plus.net [212.159.2.110]
  9    33 ms    34 ms    33 ms  195.99.126.138
10    35 ms    34 ms    35 ms  core2-te0-15-0-4.ealing.ukcore.bt.net [109.159.254.208]
11    34 ms    33 ms    34 ms  host213-121-193-230.ukcore.bt.net [213.121.193.230]
12    34 ms    33 ms    33 ms  213.137.183.98
13    34 ms    33 ms    33 ms  t2c3-xe-11-1-1-0.uk-lof.eu.bt.net [166.49.237.32]
14    36 ms    34 ms    33 ms  t2c3-xe-11-0-2-0.uk-lon1.eu.bt.net [166.49.208.18]
15    47 ms    35 ms    38 ms  tge2-1-506.edge1.lon2.uk.as5580.net [195.66.237.111]
16    34 ms    34 ms    34 ms  eth1-1.core1.lon2.uk.as5580.net [78.152.44.92]
17    33 ms    34 ms    34 ms  eth1-1.core1.lon1.uk.as5580.net [78.152.44.99]
18  119 ms  119 ms  118 ms  eth4-2.core1.nyc1.us.as5580.net [78.152.44.135]
19  123 ms  126 ms  122 ms  eth3-1.core1.ash2.us.as5580.net [78.152.45.193]
20  132 ms  124 ms  124 ms  eth2-3.r1.ash1.us.as5580.net [78.152.35.41]
21  122 ms  121 ms  121 ms  78.152.46.202
22  121 ms  120 ms  120 ms  46.229.168.33
Trace complete.
Apprentice
Try some of the tools from the link:-
http://viewdns.info/
Pinging www.postimg.org [46.229.166.179] with 32 bytes of data:
Request timed out.
Reply from 46.229.166.179: bytes=32 time=135ms TTL=53
Ping statistics for 46.229.166.179:
    Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
    Minimum = 135ms, Maximum = 135ms, Average = 135ms
Well something has changed - the links appear to be working again (15:45 4/4/15)
