possible to have banding changed?
- Re: possible to have banding changed?
25-05-2014 11:36 AM
Hi i suspect my banding could be wrong, is it at all possible to raise a ticket and have this looked in to and maybe changed?
cheers Lance
cheers Lance
Message 1 of 7
(1,192 Views)
6 REPLIES 6
25-05-2014 11:40 AM
Your line isn't banded - you have a fault
Did you report a fault as I suggested in your other thread
Message 2 of 7
(474 Views)
25-05-2014 11:45 AM
Yes i have jim, its been better today maybe its been looked at not sure, i would just like to know if it has indeed been banded at some stage.
Message 3 of 7
(474 Views)
25-05-2014 11:49 AM
As far as I know there is no such thing as banding on a fibre connection - it is specific to 21CN and maybe only ADSL2/2+ as I haven't seen a case of banding on 21CN ADSL1
Message 4 of 7
(474 Views)
27-05-2014 9:08 AM
Shows how much I know
http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
Quote What are bands?
Just like ADSL, FTTC has a number of bands that your connection will be categorised into. Please see below for a list of some of the different bands:
Message 5 of 7
(474 Views)
27-05-2014 9:09 AM
Chris Pettitt's new guide is very good and useful - http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
I didn't realise there were so many fibre bands.
Message 6 of 7
(474 Views)
27-05-2014 9:31 AM
@lancej - You've not been placed on the wrong band, however it looks as though the line is erroring, even at the speeds you've got at the moment. I can see you've raised a Fault Ticket (86122505), our Faults Team will take a look at your line and will be in touch to discuss this further.
@AndyH - The bands on the guide are a snapshot at just some of the bands. The list does go on....FTTC uses bands instead of SNR as ADSL does. I'm glad you've found the guide useful though
Message 7 of 7
(474 Views)
