port forwarding on TG585 v7 (running v8 firmware)
AJJ
hi,
I've got a trusty tg585 v7 running the v8 firmware. I tried to put in a port map last night and when I clicked apply it just rebooted itself? A while ago I added a dyndns account to the router and that has now gone -  so I think its going back to a default configuration each time.
I seem to remember I had this on the old software and there was a way of turning it off, but I can't seem to find it. Can anyone point me in the right direction?
thanks
jojopillo
Re: port forwarding on TG585 v7 (running v8 firmware)
Hi AJJ,
I'm not quite sure what you're wanting to turn off.
Jojo Smiley
AJJ
Hi JoJo,
there is something that causes the router to go back to a default configuration on reboot. So when I make changes like adding in a dyndns username or adding a port mapping for games they are lost once the device reboots.
I seem to remember on the v7 there was a check box that you needed to remove to stop it from forcing a default configuration onto the router? but I might be getting confused in my old age!!
Any ideas why any configuration changes that I make to the router arent being saved?
