pn are doing a fault check for me..i have to go out. do i leave my pc on or off?
- pn are doing a fault check for me..i have to go ou...
13-03-2008 9:56 AM
thanks
Message 1 of 3
(911 Views)
2 REPLIES 2
Re: pn are doing a fault check for me..i have to go out. do i leave my pc on or off?
13-03-2008 12:06 PM
If you have a router - just leave that on and turn the PC off. If you have a modem you probably need to leave the PC on.
Message 2 of 3
(363 Views)
13-03-2008 12:06 PM
Depends if you use a modem or router. Basically we need the ADSL hardware connected to the line and powered, so if it's a modem the PC will need to be on as this is how the modem gets its power. If it's a router it's independent of the PCs it's connected to so as long as the router is powered and plugged in to the line you don't need any PCs on.
EDIT - d'oh, beaten to it.
Hope that helps,
Hope that helps,
Message 3 of 3
(363 Views)
