plusnet speed tester is back is there a isue though
BLUECRUISER2
i am glad the speed tester is back but getting strange speed test readings connection on bt  wholsale speed test  around 2.2
speedtest net again 2.2
  but on the plusnet readings at same time 3.2  and 3,4 well above the router sinc speed of router at 2979
so to me something is a miss
Stumpy21
Re: plusnet speed tester is back is there a isue though
Hi
Working OK for me.
Derek
Infinity
Seasoned Pro
Works for me, finally able to include test results within post again.
Seems to be accurate
Rich
Quote from: BLUECRUISER2
Are you connecting through any sort of Proxy Server?
I had a 1Mb line that showed 20Mb+ when tested.  Bypassing the Proxy showed the expected speed.
Richard.
