plusnet router getting very hot and buzzing like mad
- plusnet router getting very hot and buzzing like m...
23-02-2014 1:22 PM
anyone know why this is happening ?
will i get a new router from plusnet ?
also loosing wireless connection every 5mins
Message 1 of 3
(835 Views)
2 REPLIES 2
Re: plusnet router getting very hot and buzzing like mad
23-02-2014 3:24 PM
You could try putting your router somewhere a little cooler (window-ledge for example), but it sounds as though your router might be faulty, considering the alarming noises, overheating, and frequent drops. If you call plusnet up, they can take a look at your connection dropouts, do some tests with you, and possibly organise sending you a new router (under certain conditions). How long have you had your router?
Message 2 of 3
(522 Views)
23-02-2014 3:54 PM
There have been numerous threads about noisy, hot routers. In all the previous cases PN have sent a replacement & arranged for the return of the duff ones.
Message 3 of 3
(522 Views)
