plusnet broadband usage meter
- plusnet broadband usage meter
16-10-2010 9:08 AM
hi, could anyone tell me how long it takes for the usage meter to start working.my broadband has been active for four days.ta
Message 1 of 4
(1,441 Views)
3 REPLIES 3
Re: plusnet broadband usage meter
16-10-2010 9:46 AM
A few hours, unless like me, Plusnet don't realise your service has started until you post here
At which point they will fix it and start billing you.
Message 2 of 4
(394 Views)
16-10-2010 1:42 PM
the sevice started on the 12th oct any they invoiced they same day so they know.we are on the extra 60g but still like to know what has been used
Message 3 of 4
(394 Views)
16-10-2010 3:47 PM
Do you get a "Please try later" type of message when you try to view your usage?
If YES then you may need to restart your Internet connection - it worked for me. Please note this is not your DSL connection - apologies if this was obvious to you.
Message 4 of 4
(394 Views)
