plusnet assist fix problem
- plusnet assist fix problem
15-06-2014 7:41 PM
Hi everyone, I am a newbie. I have just started with Plusnet and my email is not working properly so I was told by the assist program to click fix which I did . I am then told my internet explorer browser is not compatible so I changed default to Firefox.
Guess what the software still opens IE browser. Huh?
Any Ideas how to correct this?
Sijsonowill
Sijsonowill
Message 1 of 2
(428 Views)
1 REPLY 1
Re: plusnet assist fix problem
15-06-2014 7:50 PM
Don't do it
There is plenty of advice on the forum to fix all problems just post your problems
The Assist programme will just deal with a vanilla set up and undo any special configuration you may like
I went overseas to work and assist screwed up our email settings putting my wife out of contact
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 2 of 2
(247 Views)
