plusnet Email sent form mobile phone Help
- plusnet Email sent form mobile phone Help
- « Previous
- 1
- 2
- Next »
Re: plusnet Email sent form mobile phone Help
29-05-2009 11:49 AM
Were they as helpful as the Three web help pages?
As in, "not very"?
As in, "not very"?
Message 16 of 22
(518 Views)
29-05-2009 12:12 PM
Quote Three used to allow you to send email through email servers running on port 25 through their Mobile Broadband, then it suddenly stopped working a few weeks back
I wasn't imagining it then!
Message 17 of 22
(518 Views)
29-05-2009 8:12 PM
Quote from: MrC Tah-dah.....
OK, just found the following info on t'web which someone winkled out of 3 support.
Change the smtp server to smtp-mbb.three.co.uk as this one doesn't rewrite addresses on the fly in the same way that smtp.three.co.uk does. I assume that smtp.three.co.uk is solely for 3's own email service and that smtp-mbb.three.co.uk is for evryone else (mbb == mobile broadband?). Note: normally email sent through smtp.three.co.uk doesn't get counted against your data allowance; I'm not sure if this is true for smtp-mbb.three.co.uk so you might want to experiment before sending large attachments.
I can now send email from a 3 mobile with the from and reply-to headers set to whatever I want - yippee!
Mike
Thanks for the help, its now working through three's servers, although i haventy tried it on the phone +laptop liknk yet
Message 18 of 22
(518 Views)
11-07-2009 11:26 AM
Thanks guys. I used the mbb smtp and it now works. I wish that Three would get their act together. I am very tempted to pay £50 and get out of the contract however will I be better off with another provider. I use a 3 Huawei modem connected to my laptop when away from home. Is there a really good mobile broadband network that does not drop the connection every 10 minutes even when you are in a good coverage area?
Message 19 of 22
(518 Views)
11-07-2009 11:40 AM
I’ve had the same problem although I’m with orange not 3
Use ure network smtp to send and ure plusnet to receive emails
This I’ve done and it works
regards
regards
Message 20 of 22
(518 Views)
07-10-2009 2:31 PM
Quote from: Surfer I use a 3 Huawei modem connected to my laptop when away from home. Is there a really good mobile broadband network that does not drop the connection every 10 minutes even when you are in a good coverage area?
Have just got a Vodafone Huawei USB modem which seems to work quite well. Once it is connected it stays connected.
Message 21 of 22
(518 Views)
07-10-2009 11:23 PM
Drat. Just to prove me wrong, the connection kept dropping out tonight. Signal kept going from 3.5G to GPRS to nothing. Internet was virtually unusable.
Message 22 of 22
(518 Views)
- « Previous
- 1
- 2
- Next »
