plex media server not working with plusnet Technicolor router
melvisplus
hi
i suddenly cant connect to plex media server.i never used to have a problem with this server but i cant connect to it now .plex forums say i have to check whether my router supports upnp or NAT-PMP
Fixes: 20
Re: plex media server not working with plusnet Technicolor router
Is this from INSIDE your network or from outside (ie away from home)?
If it is inside then the ip address has probably changed. If outside then it may be upnp related, it is normally on but check in the router setup screens (192.168.1.254)
melvisplus
hi
the problem is from inside the house i recently reinstalled windows and it worked after but suddenly stopped
pwatson
Windows firewall?
Fixes: 20
OK if it is inside then it has nowt to do with the router, that is a red herring.
As above make sure that the plex ports are open on your LOCAL pc firewall, double check the ip address is the same, have you installed any extra s/w since it was working?
Do some PN routers not already run a DLNA server ?  If they are on the same ports as the Plex server it may cause issues.
Fixes: 12
i run a plex server in my local network with the TG582N and have no issues at all.
no ports needs opened on the router (even for external access).
it's all done via uPNP, so make sure that is enabled on the router.
by default, plex server uses port 32400 for internal traffic.
make sure that port is open on you local system level firewall.
Plusnet Staff
Plusnet Staff
Fixes: 5
Yeah I run Plex and it works absolutely fine on my Technicolor.
Make sure your Firewall isn't blocking it or any of your antivirus programs that have firewalls built into them.
Chris Pettitt
Cloud Environments Engineer
melvisplus
hi
i have disabled both window firewall and my anti virus but plex still saying cant connect to servers .How do i check the plex ports are open on my firewall and check the ip address is the same ,i am not that good at this kind of thing ,help much appreciated .
mick
pwatson
Lets start with the basics:
1.  Has anything changed in your setup?  You say it used to work and has only stopped working after a Windows rebuild on your PC so this seems to be where to look first.
2.  Has this worked with the PN router prior to the Windows re-install?  If so, and you haven't made any changes to the router then this also points at your PC.
3.  Where is your Plex server?  Another PC, a NAS or something else?  Is the server cabled to the router or is the connection wireless?
4.  Is the connection to your PC wired or wireless?  If the answer to 3 or 4 is wireless, connect everything to the router via ethernet cables for now.
Please give as much detail as possible about what your system is as we can't see it  Wink
melvisplus
hi
my pc is the plex server and is where all the movie files and music are stored etc.Plex worked after re-install of windows on the PN router .in addition to this my pc has always been wired via ethernet to my PN router .
regards
mike
pwatson
Where is the client that is trying to access Plex?  On a wired or wireless connection?
Again, what has changed in your setup and can you fully describe your setup?
melvisplus
hi
its on a wired connection from my desk top
pwatson
So it's not the router then as the server and client are both connected via the switch part of the router.
I can't help any more I'm afraid as you really aren't giving much away Sad
Fixes: 12
stop drip feeding information and answer ALL the questions that have been asked.
