pingtest.net broken?
Fixes: 21
Anybody else having problems? Two of us had problems for over an hour.
Fixes: 58
Re: pingtest.net broken?
Not working correctly for me (I did check the WAN Ping setting in my router)
Tried a different server (Dublin) and it worked.
Customer and Forum Moderator.
RPMozley
Fixes: 5
Maidenhead and Milton Keynes appear to be failing with the packet loss testing. It's not timing out as it would do if there was a problem so it must be a configuration issue with those servers.
If you turn off packet loss testing by disabling Java, those two servers still work ok.
That's RPM to you!!
Fixes: 10
A test to Maidenhead (Xilo) has just worked for me.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
