pingtest.net broken?
- Re: pingtest.net broken?
05-07-2012 2:30 PM
Anybody else having problems? Two of us had problems for over an hour.
Message 1 of 4
(1,042 Views)
3 REPLIES 3
05-07-2012 2:35 PM
Not working correctly for me (I did check the WAN Ping setting in my router)
Tried a different server (Dublin) and it worked.
Message 2 of 4
(452 Views)
05-07-2012 4:44 PM
Maidenhead and Milton Keynes appear to be failing with the packet loss testing. It's not timing out as it would do if there was a problem so it must be a configuration issue with those servers.
If you turn off packet loss testing by disabling Java, those two servers still work ok.
That's RPM to you!!
Message 3 of 4
(452 Views)
05-07-2012 5:04 PM
A test to Maidenhead (Xilo) has just worked for me.
Message 4 of 4
(452 Views)
