pingtest graded as B and now slow dowload 0.2 speeds
dave1240
I have a new bt home hub 3 directly connected to the master socket I am using a bt iplate.
My broadband just now came to a stand still but the speeds are fine but I have 25ms jitter for the first time ever. The slow loading stand still is normal I was hoping it was my old router.
What could be the issue is it the wire from socket to router ?.
dave1240
Re: pintest grade B what is the problem.
I have just fitted another rj11 cable and I am having really poor download speed now I am normally 11.5.
Connection information
Line state:  Connected
Connection time:  0 day, 00:23:55
Downstream:  872 Kbps
Upstream:  552 Kbps
ADSL settings
VPI/VCI:  0/38
Type:  PPPoA
Modulation:  G.992.3 Annex A
Latency type:  Interleaved
Noise margin (Down/Up):  4.6 dB / 5.9 dB
Line attenuation (Down/Up):  66.5 dB / 38.7 dB
Output power (Down/Up):  0.0 dBm / 12.8 dBm
FEC Events (Down/Up):  132267 / 154
CRC Events (Down/Up):  505 / 0
Re: pingtest graded as B and now slow dowload 0.2 speeds
Can't see anything this side that might be slowing you down, are BT speed test results (http://www.speedtest.btwholesale.com) showing similar results? Your line profiles are showing you should be getting speeds around 12.5Mb.
If the BT wholesale results comes back showing similar to your speedtest.net results there please raise this to us as a fault at http://faults.plus.net and we'll get it investigated for you.
dave1240
Everything is fine now I have no idea what happened but my speeds and jitter is fine now.
dave1240
Hello again I have just checked the BT test again and all is fine but I have noticed this on the BT test.
Download speed achieved during the test was - 12 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 12.59 Mbps
Is it possible to get nearer the 21Mbps or am I capped at 11Mbps ?.
Only enquiring but would be awesome to get more speed for all our users :-).
Are you able to connect to your test socket and I can check your conenction again to see if there's any change?
dave1240
Hi Chris I am connected to a BT iplate before I remove it and go directly into the master socket what exactly are you trying to find. Are you testing to see if I can achieve a faster connection ? I only ask because the master socket has a unit directly in front of it.
dave1240
These are pretty much my normal speeds
Would like to see if it does make any difference and also to rule anything internal out. It's not a necessity but will help identify if there are any issues.
