ping
monkey001
ping
ping is all over the place and speed drops cant load pages
i know i have interleaving off but it was fine for a good couple of monthes now things seem to have gone back to being crap can you do some tests on my line cause im getting fed up with coming on and complaining every other month
Re: ping
Hi monkey001
Can you post up some pings and traces to the IP's your seeing latency on?
Can you also post up the full results from a BT Speedtest?
monkey001
Re: ping
the ping is more a problem as you can see normaly its sat around the 20s i take it from the other thread im reading its PN again?
monkey001
Re: ping
i want my mac code NOW
