ping times through the roof
- ping times through the roof
25-04-2009 12:21 AM
just been gettin major lag on cod waw.
had quick check round pc's make sure they were on the best behaviour and they were.
done a tracert to bbc.co.uk and boy o boy
changed ip address ect every thing i can do to make sure its not my end at fault
iam on thn-ag2 due to being on the 21cn trial and connected by adsl g.dmt mode at the mo. i will check what the packet drop was like on thn-ag2 later. it seems to have kicked in around midnight this is the first lag i have seen since i joined PN a couple of years ago. i forgot what a pain in the rear lag is
i posted here due to it not justing being gaming pings that are up the swanie
EDIT:
they have started to stablize now at 00.40.
time to go back to the killing field and see if every ones stoped hopping around the map like frogs
Quote Tracing route to bbc.co.uk [212.58.254.252]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 10.0.0.1
2 119 ms 77 ms 29 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 48 ms 85 ms 24 ms vl604.thn-gw2.plus.net [84.92.4.170]
4 80 ms 18 ms 101 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 43 ms 35 ms 18 ms 212.58.238.133
6 67 ms 37 ms 31 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
7 20 ms 59 ms 42 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
C:\Users\>tracert bbc.co.uk
1 * 1 ms 1 ms 10.0.0.1
2 41 ms 66 ms 57 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 43 ms 45 ms 64 ms vl604.thn-gw1.plus.net [84.92.4.169]
4 222 ms 54 ms 45 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 227 ms 35 ms 70 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 65 ms 65 ms 28 ms 212.58.238.133
7 116 ms 32 ms 28 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
8 54 ms 48 ms 64 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
C:\Users\>ping bbc.co.uk
Pinging bbc.co.uk [212.58.254.252] with 32 bytes of data:
Reply from 212.58.254.252: bytes=32 time=60ms TTL=249
Reply from 212.58.254.252: bytes=32 time=47ms TTL=249
Reply from 212.58.254.252: bytes=32 time=133ms TTL=249
Reply from 212.58.254.252: bytes=32 time=31ms TTL=249
Ping statistics for 212.58.254.252:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 31ms, Maximum = 133ms, Average = 67ms
Reply from 212.58.254.252: bytes=32 time=39ms TTL=249
Reply from 212.58.254.252: bytes=32 time=21ms TTL=249
Reply from 212.58.254.252: bytes=32 time=62ms TTL=249
Reply from 212.58.254.252: bytes=32 time=556ms TTL=249
Minimum = 21ms, Maximum = 556ms, Average = 169ms
EDIT:
2 19 ms 23 ms 20 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 18 ms 20 ms 17 ms vl604.thn-gw2.plus.net [84.92.4.170]
4 22 ms 18 ms 17 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 23 ms 20 ms 21 ms 212.58.238.133
6 20 ms 21 ms 18 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
7 21 ms 26 ms 22 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
C:\Users>tracert bbc.co.uk
2 18 ms 17 ms 20 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 20 ms 21 ms 228 ms vl604.thn-gw2.plus.net [84.92.4.170]
4 28 ms 24 ms 21 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 43 ms 20 ms 37 ms 212.58.238.133
6 17 ms 18 ms 16 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
7 18 ms 17 ms 16 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
2 34 ms 19 ms 29 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 21 ms 17 ms 23 ms vl604.thn-gw2.plus.net [84.92.4.170]
4 17 ms 16 ms 16 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 17 ms 16 ms 18 ms 212.58.238.133
6 19 ms 20 ms 23 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
7 24 ms 27 ms 18 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Message 1 of 4
(1,130 Views)
3 REPLIES 3
Re: ping times through the roof
25-04-2009 2:21 AM
all back to normal now. packet drop on thn-ag2 is normal
think its going to be one of those that i will never no what the cause was.
but iam going to point the finger at BT's 21cn network as its never happend before now or might just be me being a sore loser on the thoughput increase on adsl2 thats made me even more angry at BT and quick to point the finger
2 17 ms 19 ms 17 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 18 ms 18 ms 16 ms vl604.thn-gw2.plus.net [84.92.4.170]
4 16 ms 16 ms 16 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 16 ms 16 ms 16 ms 212.58.238.133
6 17 ms 16 ms 16 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
7 17 ms 17 ms 17 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
Trace complete.
Message 2 of 4
(453 Views)
25-04-2009 5:21 AM
That depends on what you think is normal for the packet drops. I think the peaks are far greater than they ever used to be.
Message 3 of 4
(453 Views)
25-04-2009 5:45 PM
o yeah there peaking higher since unlimited but on the thn-ag2 box last night they where below average for the midnight peak
Message 4 of 4
(453 Views)
